Click, click click - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-23-2003, 07:47 PM Thread Starter
Click, click click
Often when i wanna stat up my sammi, turn the key and hear click and no go. Do i do it again and again and again and finaly she will fire up. I don't know what is causing this. All my connections are tight and it's a new starter. Got any ideal?
Dxray is offline
post #2 of (permalink) Old 02-23-2003, 08:15 PM
Re: Click, click click
Mine does the same thing all you need to do is tap on the starter celnoid(sp).It should start up right away only happens to me once in a while as well.Hope this helps.
iicharter is offline
post #3 of (permalink) Old 02-23-2003, 08:28 PM
MrBraindamage
I've got the same problem with mine whens it's cold.
I wish I new and I would fix it. I don't thinks it's anything to do with the starter itself.
post #4 of (permalink) Old 02-23-2003, 08:36 PM Thread Starter
Like if i jump the selonoid it fires up. IT started to do the same with the old starer. [img]images/graemlins/confused.gif[/img]
Dxray is offline
post #5 of (permalink) Old 02-23-2003, 08:40 PM
Skip
It's the starter solenoid. Some people replace it with a firewall mounted Ford type. Pull and clean it. Lube
it with a marine grease.
Also and "my soap box", check battery cables and all grounds. Frame to engine, body to engine, body to
frame. All should be #8 or larger (lower number larger wire). Crappy grounds = crappy problems.
[img]images/graemlins/RockOn.gif[/img]
post #6 of (permalink) Old 02-23-2003, 08:46 PM
MrBraindamage
I think it's something to do with the switch. Sometimes when I switch mine off it dosn't stop running immediately.
post #7 of (permalink) Old 02-23-2003, 08:58 PM
HankS
Do a search for clicky starter fix.
post #8 of (permalink) Old 02-23-2003, 09:11 PM
This is a commmon problem with Zuks. What you need is a starter relay. You can get one for $25 through any Zuke vendor, or just buy the relay for about $3 at the auto parts store and wire it yourself.
If you do a search for "starter relay" you can find a wiring diagram someone posted a while back.
ZippytheZuke is offline
post #9 of (permalink) Old 02-23-2003, 09:35 PM
mine has done this for a while itself. It only gets worse, now when I go to start it makes this grinding noise. I have to wait/play with it will start up no questions asked...weird and scary
studlybil03 is offline
post #10 of (permalink) Old 02-23-2003, 10:54 PM
87zuke's Avatar
Starter Fix I'm going to do this when it wams up and the snow stops. Jim
87zuke is offline
