rear disk brakes - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-29-2002, 07:00 PM Thread Starter
rear disk brakes
who has rear disk brakes and how did you do it.
the lil'searchy thingy is not working. i'm already swaping out the rear-end so i have it on the work bench i want to do everything at once then slide it under the zuk.
this is a daily driver 99.99% so would this be a bad thing for the streets
i have most all the stuff to do rear disk breaks.
can i cut the rear drums down to the circle just past the studs.
also what about the t-case e-brake how do i go about that. do i go and get a motor cycle set up. where do i find a cable e-brake. i found in the junk yard that the izuzu tropper had rear disk with cable e-brake. i dont know what the bolt pattern is but i have a complete zuk front-end at my finger tips so the t-case would be better
GA_ZUKI is offline
post #2 of (permalink) Old 12-29-2002, 07:22 PM
Carpal \'Tunnel
JIMZUKI's Avatar
Re: rear disk brakes
howdy,
i am getting read to do my weld on and here are the 2 rite ups i am usen. zukdiscs at BC4x4.com & welddiscs at ORC . and now for the new buttons [img]images/graemlins/givemebeer.gif[/img] [img]images/graemlins/AR15firing.gif[/img] [img]images/graemlins/bs.gif[/img]
JIMZUKI is offline
post #3 of (permalink) Old 12-29-2002, 07:47 PM
WSB
Izusu Trooper would have a 6 lug bolt pattern. If you look at the Sami drums, there is a ridge that is approxiamtely were my drums were cut down. They fit inside the rotor with about 1/8" or so to spare. I using early 80's Suburu calipers so the e brake problem will taken care of with those. I should only have very minor modifications for the parking brake to work.
Wayne
WSB is offline
post #4 of (permalink) Old 12-29-2002, 08:35 PM
What all did you take from the subbie? I hear you need a few parts to make it work.
post #5 of (permalink) Old 12-30-2002, 04:46 AM
WSB
I bought loaded calipers and the rubber hoses from Parts America. The calipers are from a 1980-82 Suburu 1600. The hoses are too long, I may look for another set that are shorter. I still need to get the banjo bolts that bolt the hoses to the calipers and a proptioning valve. I also have to make up some brackets to hold the caliper once I have everything ready. I can't see it being difficult to make it work.
Wayne
WSB is offline
post #6 of (permalink) Old 12-30-2002, 06:07 AM
I heard tha sammy banjo bolts where longer and someone used them, might fit who knows..keep us updated.
