oh no not again!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-28-2002, 11:19 AM Thread Starter
oh no not again!!
well everything was working fine and the new alternator
died, is there possibly something causing this?
maddog is offline
post #2 of (permalink) Old 12-28-2002, 11:48 AM
Re: oh no not again!!
Does this thing have an internal or external regulator? also check your battery for a dead cell.
outlawmws is offline
post #3 of (permalink) Old 12-28-2002, 12:00 PM Thread Starter
internal regulator, brandnew battery had checked when i took alternator to get replaced, with motor running its putting out 12 volts and when i turn on headlights its still putting out 12 volts it took a couple of hours driving with headlights on before i noticed lights were slowly dimming, where before it took 15 minutes with the last alt
maddog is offline
post #4 of (permalink) Old 12-28-2002, 12:02 PM
Nowhere's Avatar
Sounds like you may have bad ground syndrone.. Replace the ground strap with a #10 guage strap between the distributor housing and the firewall. Get another ground on that battery and make sure the starter cable ground is in PERFECT condition, replace if needed.
[img]images/graemlins/laugh.gif[/img]
Nowhere is offline
post #5 of (permalink) Old 12-28-2002, 12:19 PM
dparker's Avatar
when havening alt die on you aali 101
run a 10g wore from the stud on the alt strait to the battery , make sure your gettin a ful 12v at the switched igtion wire on the gree plug on the back of the alt . then run you a extra ground .
dparker is offline
post #6 of (permalink) Old 12-28-2002, 01:30 PM Thread Starter
i found problem i think i soldered all crimp on connectors
battery cables i had already replaced all my grounds, found the alt belt was a tab loose tightened it up, and it bumped up to 13 volts idling 12 volts with headlights on, so out of desperation i removed the brand new battery and put in old one i had laying around that i use with my trolling motor, cleaned up the post and connected everything, and 14 volts idling, 14 volts with headlights on 14 volts with everything on, so either my brand new battery that was just tested yesterday as being good, is fooling us, or my new alternater is intermitting, its been running with everything on for quite awhile now and still holding its
own,
i was about to run 10 guage wire from alt to batt but wasnt sure if i should but thats something ill remember
thanks
maddog is offline
post #7 of (permalink) Old 12-28-2002, 05:37 PM
dparker's Avatar
i sitll would run it with all the trouble your haveing it cant hurt
dparker is offline
post #8 of (permalink) Old 12-28-2002, 05:44 PM
go to your local bone yard and get a trackick primary harness... has the cool fuse box and nice fat alternator wiring.. I did this to my Zuk and it's sweet!
Mini4x is offline
post #9 of (permalink) Old 12-29-2002, 06:47 AM Thread Starter
after running it all day with no voltage drops, it droped half way to workso i had wife charge up a battery and bring to me and after work i put charged battery in and it still showed just 12 volts, then my brake fuse popped and everything went back to normal, so im assuming my problem may be in that area what do you guys think? oh i am going to run the jumper from alt to battery just for kicks
maddog is offline
post #10 of (permalink) Old 12-29-2002, 03:18 PM Thread Starter
this $#*! is driving me crazy !!!!!!!!!
maddog is offline
