saganaw PS pump install. Opinions? Heat affect? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-27-2002, 06:52 PM Thread Starter
i spent the second half of this afternoon mounting this up.
stole the crank pulley from a AC 1.3 and used part of the lower ac pump bracket to hold on the power steering pump. lined it up and used spacers. The pulleys are running pretty true to each other. steering shaft clearence is an issue, but my main question is about the header? its really close to the one tube. should i wrap the tube and call it good, or should i shove some more stuff inbetween? im kinda worried about the one tube getting the pump and hydraulic fluid hotter than it will already be getting.
i plan on running a big trans cooler to it also.
in general does it look AOK?
thanks.
thanks!
Zach
BurnedBronco is offline
post #2 of (permalink) Old 12-27-2002, 07:13 PM
dparker's Avatar
Re: saganaw PS pump install. Opinions? Heat affect?
in my opinon aint very mean of use running that setup mine works fine But i did add a cooler to the ps system to help it run cooler .
i would dont rape the header makes them rust out might put a heat Shelid inbetween there though
dparker is offline
post #3 of (permalink) Old 12-27-2002, 08:34 PM
Carpal \'Tunnel
JIMZUKI's Avatar
howdy,
i would wrap the header with some Thermo-Tec Header Wrap . i ues the 2'' x 50' Black Graphite. cost is $46.99 + shipping here's a pic of mine.
then add in the Perma-Cool Power Steering Two Pass Cooler. cost is $31.99. and now i have to do is get my power steering box and pump.
by the way where did you get you pump? what box are you using? and are you going to run a resivor? sorry so many question.
JIMZUKI is offline
post #4 of (permalink) Old 12-27-2002, 08:51 PM Thread Starter
pump was off the axle donor rig. off of a 1980 345CI scout II motor. used its bracket also.
I'm not using a box. See that green thing the steering shaft is going to? thats my valve. This things going full hydraulic. Im going to use the stock resovior with a big cooler. with all the lines it should have plenty of fluid to keep it cooled down.
post #5 of (permalink) Old 12-28-2002, 01:12 AM
dparker's Avatar
I got ,y PS cooler of a yota Pk up truck if you have 1 close
dparker is offline
post #6 of (permalink) Old 12-28-2002, 09:52 AM
If your going full hrdro add a cooler.. also what are you using for the valve?
rockrat is offline
post #7 of (permalink) Old 12-28-2002, 06:43 PM Thread Starter
I am running John Deere combine parts. The ball valve and cylinder are from a 7700 series combine. the cylinder is the exact perfect length for lock to lock on my scout D44 also. i will have rufly $150 in the whole hydraulic steering including hoses.
the valve is two valves instead of one like most valves you see, but easily mounted. the orbital valve is in that colloum in the pic, and two lines go from that to that other valve on the right which have the lines going to and from the pump, and to and from the cylinder.
