Does this combo do well? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-27-2002, 04:48 PM Thread Starter
Does the 15x8 rim with a 31x10.50 do well. Was there someone that said they did not like the combo or did it just not perform well. I just got a set of 15x8 rims with 2'backspace for real cheap. And I want to run the tires I have now on them. I am going to be running 33' in the future with them. Thanks alot TOM
boyirish6 is offline
post #2 of (permalink) Old 12-27-2002, 05:02 PM
Re: Does this combo do well?
I run them now and they do fine. Alot depends on what kind of wheeling you do.
sapp1090 is offline
post #3 of (permalink) Old 12-27-2002, 05:12 PM
zukiman
That wheel/tire combo will work fine. It will also work with a 33x12.50 for your future upgrade. Good thing it's got the small backspacing, otherwise when you upgraded to 33's, you'd probably find the front tires would rub the springs.
--Geoff Beasley
post #4 of (permalink) Old 12-27-2002, 05:18 PM
DangerousDarren's Avatar
should have no problem. i run 31x10.5's on 9.5" rims. i just don't air down any lower than 15psi, but you should be fine to around 10 psi.
DangerousDarren is offline
post #5 of (permalink) Old 12-28-2002, 12:32 AM
I run that combo and have aired my MTR's down to less than 5 psi rockcrawling without problems. The only issue is the rocks will get the edge of the rim until you go wider with the tires.
moozuki is offline
post #6 of (permalink) Old 12-28-2002, 03:14 AM
you do have to be carefull in gritty mud and fine gravel, i have had trouble with a rear not holding air due to small pieces of gravel working down in between the rim and the tire bead. other than that no problems. before that i ran 32x11.5's on 10 inch rims and had no problem. see pic
File Type: jpg 981675-bobby driving my zook bbs size.jpg (81.9 KB, 28 views)
post #7 of (permalink) Old 12-28-2002, 09:09 AM
87zuke's Avatar
I'm confused. Isn't the 8" rim the correct rim for 10.5" tires? I have a set of 15x6 rims and thought they are too small for 31x10.5 tires. Thanks. Jim
87zuke is offline
