my choke is only opening about1/3 of the way. The vac pot is pulling back all the way but choke remains about 2/3 closed. is there a 2nd pull off as it warms up? If so how do check it? I can open it all the way on the out side of the carb on the left where the round springs and all these little connectores are. I just replaced all my vac lines and it will now run up the road pertty good but when I try to give it to much gas it stalls. I think the choke is slaping shut.
I still haven't replaced my muffler, I think it's plugged with loose fiberglass. as I get a PUFF every so often and little bits of glass blow out!
Will look for answers when I get back from El. Paso Tx this coming Fri.
TKS.
