2 questions - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-22-2002, 11:29 AM
2 questions
I am rebuilding my carb and a nice gentleman on the board helped me out with the suzuki shop manual instructions. One of the directions entails using a "negative screwdriver." anybody have a clue what that is? Also, when i reinstall my carb, should I use some kind of gasket sealant or just leave them "dry." I am sure that gasket sealant isn't what I mean, but i have done things in the past where you applied some goo to the gasket and the name escapes me right now. thanks
kuriti
post #2 of (permalink) Old 11-22-2002, 11:58 AM
SPAMurai
Re: 2 questions
i think the best solution would be to just buy the carb from my new parts samurai! lol...
never heard of a negative screwdriver. good luck with it,
steve o'
post #3 of (permalink) Old 11-22-2002, 12:43 PM
Re: 2 questions
Have no idea about a negative screwdriver but it might mean useing one that isn't magnatized. The gaskets should be fine as they are with no added goo.
sky_hi_samurai is offline
post #4 of (permalink) Old 11-22-2002, 12:49 PM
Pooh-Bah
DougO's Avatar
Re: 2 questions
Hmm, maybe a phillips is a + positive and a flat is a - negative [img]images/graemlins/grin.gif[/img]
DougO is offline
post #5 of (permalink) Old 11-22-2002, 01:11 PM
Re: 2 questions
thats as good as i could figure as well. I thought maybe they meant a pesimist screwdriver. But what does a screwdriver have to complain about, all it does is screw all the time.....
kuriti
post #6 of (permalink) Old 11-22-2002, 01:25 PM
Re: 2 questions
I cannot recall ever needing any sealant on a carb gasket.
But as someone on the board has managed to remind me recently,
I'm in that old and decrepid stage of life and may have forgotten!
outlawmws is offline
post #7 of (permalink) Old 11-22-2002, 01:35 PM
Re: 2 questions
i put gasket sealant on mine later after the gas ate it away or somthing like that i had nasty vacume leaks the new one is dry no problems yet
szki272 is offline
post #8 of (permalink) Old 11-22-2002, 04:05 PM
Re: 2 questions
GOO + CARB/GAS = BAD
and as for the screwdriver goes [img]images/graemlins/confused.gif[/img] [img]images/graemlins/confused.gif[/img] [img]images/graemlins/confused.gif[/img]
weasel is offline
post #9 of (permalink) Old 11-22-2002, 06:34 PM
Re: 2 questions
OK I just got home and looked up the carb overhaul section. I have a guess what they mean
about "negative" screwdriver. The are talking about removal of the jets in the float bowl, and
any damage to the jet can cause it not to flow properly. Using a screw driver with the usual
tapered grind can cause it to slip on the soft brass and damage those jets.
A hollow ground screwdrver that fits tight is less likely to slip. So my guess is "negative" screwdriver
means a hollow ground screwdriver. These are commonly sold to gunsmiths as they must have
tight fitting hollow ground drivers or they will tear up thre heads of the screws, if they don't
slip and damage the blueing on the gun.
