Question about the breather tube on the diffs? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-21-2002, 01:59 PM Thread Starter
Who here on this board has taken the breather tube off on the differentials, tcase, tranny?
is it threaded into the housing for a samurai?
thanks for any constructive responce...
rich_d is offline
post #2 of (permalink) Old 11-21-2002, 02:30 PM
Nowhere's Avatar
Re: Question about the breather tube on the diffs?
My breathers are now halfasialy tubed to up front, the transmission and x-fer case are tapped with 1/4" NPT 90* elbows (ace hardware, about 4 dollars for the 90* and the pipe threadded end) and removed the stock breather caps on the tranny and x-fer, drilled them, tapped them, used teftlon tape, and put it all together. Get the drillbit and tap kit for the 1/4" NPT fittings, Super simple, both units MUST be out of the zook! I pointed the tranny one towards the passenger tire and the transfer case towards the rear passenger tire (estimates...).
I had then used some 10 dollar air hose and some 2 dollar fuel filters and have them halfasialy plumbed into the engine bay (weber + snorkel soon, will redo the breathers then.).
[img]images/graemlins/laugh.gif[/img]
Whole cost for the pipe, 2 fittings, drill bit, and tap was about 25 dollars give or take.
Nowhere is offline
post #3 of (permalink) Old 11-21-2002, 02:36 PM Thread Starter
I was hoping that they were already threaded in and all I would have to do is take the threaded sheath out and put a threaded 1/4" fitting on it,
I did not want to take them out..
rich_d is offline
post #4 of (permalink) Old 11-21-2002, 02:49 PM
On the diffs, I just took of the cap, and used a little silicon and a hose clamp to put a 1/2 inch ID hose on...
Not sure if the tranny and t-case can be done the same way.
BTW I popped the caps off with vice grips...
post #5 of (permalink) Old 11-21-2002, 03:11 PM
Jbird's Avatar
I did both diffs, t-case and tranny. All are piped into my snorkel.
The diffs are easy..just pop the caps off and your hose will slip right over and can be hose clamped. The tranny and t-case look about the same but there isn't alot of nipple sticking up and there isn't a lot of room to make a bend in the hose before the hose hits the body. I'm not sure what size hose I used, but I was able to get a hose on the existing nipple in the t-case and get a small hose clamp on it. So far it's worked great.
Jbird is offline
post #6 of (permalink) Old 11-21-2002, 03:19 PM
Carpal \'Tunnel
JIMZUKI's Avatar
howdy,
i cut mine off with a hack saw when i did the spoa and then added neumatic air tube to let them flex up and down here's a pic.
i had to put a hose into the metal part of the diff to attach it to the neumatic tuben. hope this is a good idea for you. i also use this on my tranny and t-case. the neumatic hose is great because it is perbent and flex as much as you need it to.
JIMZUKI is offline
post #7 of (permalink) Old 11-21-2002, 03:44 PM
Nowhere's Avatar
Yup, I was worried about streess and the hose binding without a 90* tap on the tranny and transfer, I also was pulling the engine, so while I was there.................
Nowhere is offline
post #8 of (permalink) Old 11-21-2002, 03:47 PM
Nowhere's Avatar
When I used some thick air hose, it'd fall off the small nipple on the transfer case, I tried glue/silicone, it just fell right off, that's why I went with the 90* fittings.
Nowhere is offline
post #9 of (permalink) Old 11-22-2002, 06:51 AM
One of my good friends and life long NHRA pit crew mechanic had me run my diff breathers tubes into the hose that comes off the valve cover just before your PCV valve.
I cant recall the exact science behind it, but it works for me, and if water is getting in your valve cover youre screwed anyway! Nothing like a little hydro in your engine
James
Kamazuki is offline
