spring centering bolt question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-18-2002, 09:26 PM
pugrocker
I will need to replace the spring centering bolt for my hybrid rear up front setup and CJ front springs to be used in the rear but I pretty much destroyed the spring centering bolts when I was rebuilding the spring packs. I went to PepBoys and bought a 5/16" x 2" long hex nut bolt as a replacement but as it turns out the head is too small for the spring perch..........what size should I get - 1/2"? I do not want to have to (drill out) increase the size of the hole in the spring packs.....TIA
post #2 of (permalink) Old 11-18-2002, 10:02 PM
Skip
Re: spring centering bolt question
You should use whatever size came out of the spring pack otherwise there is movement and you could end
up breaking the bolt again. I buy spring bolts from my local 4x4 shop
post #3 of (permalink) Old 11-18-2002, 10:27 PM
This is prolly not the best way to do this but when I needed a replacment bolt I just found one in my clooction of nuts and bolts that fits the hole good and then ground the head of the bolt round. worked just fine
Tanzuki is offline
post #4 of (permalink) Old 11-19-2002, 02:31 AM
CrowHorse's Avatar
I have a pair of the next size up, whatever that is. I'll call you at work.....You can have these.........
CrowHorse is offline
post #5 of (permalink) Old 11-19-2002, 05:37 AM
MrSurly's Avatar
I used 5/16" hardware on mine. They didn't seem too small for the holes. Are you talking a little bit too small or way too small?
MrSurly is offline
post #6 of (permalink) Old 11-19-2002, 05:56 AM
The spring centering bolts are 8mm, with a 12mm head . If you have any old driveshaft bolts laying around they work good . Be careful how much you grind down the head to make them round, too much and they will fit loosely . These bolts are very important, as they maintain the wheelbase and keep the spring packs from moving .
Sarge
Sarge is offline
post #7 of (permalink) Old 11-19-2002, 11:14 AM
After I broke mine tryin to turn it around. I took the broke one and went up to Lowes, and got the same size bolt. Dont remmember the size but it worked fine.
studlybil03 is offline
