twin cam + tank for carburated - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-17-2002, 09:50 PM Thread Starter
Did anyone used the stock gaz tank for a carburated with a twin cam engine ?
I use the stock tank with an external pressure pump, but my pump seem to have trouble pumping the gaz through the stock metal gaz line + fuel filter. The pump is near the engine.
xfaktor is offline
post #2 of (permalink) Old 11-17-2002, 09:59 PM
Re: twin cam + tank for carburated
I belive the stock tank works on a siphon principle. The fuel pump works best when it is down low. I have mine mounted where the stock fuel filter was and it works fine.
whazoo is offline
post #3 of (permalink) Old 11-17-2002, 10:17 PM Thread Starter
did you put the filter before or after the pump ?
and you used the stock metal line from the pump to the engine ?
xfaktor is offline
post #4 of (permalink) Old 11-18-2002, 07:35 AM
I placed the filter before the pump (between the tank and the pump...no worries for a high pressure filter this way).
I used the stock sammi fuel line as the fuel line. I also used the vapor canister vent line as the fuel return line (its almost the same diameter as the fuel line) and the tiny sammi fuel return line is now the canister vent line. I switched how they connect to the tank so everything works OK. You'll want to double clamp everything as well.
whazoo is offline
