Oill leak from fuel pump - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-14-2002, 01:41 AM Thread Starter
I changed the O-ring on the distributor and cured that leak and now have discovered that the fuel pump appears to leak oil from the tube on it. Can I mash the tube flat to seal it or do I have to replace the fuel pump?
Nuttman1 is offline
post #2 of (permalink) Old 11-14-2002, 03:10 AM
Re: Oill leak from fuel pump
When it leaks from that tube it means its time to replace the pump, it will fail soon if it hasn't already.
moozuki is offline
post #3 of (permalink) Old 11-14-2002, 05:50 AM
Also check you pcv system. My pcv valve and hose stopped up and cause my to leak a little oil.
Steve
ka4yqi is offline
post #4 of (permalink) Old 11-14-2002, 07:05 AM
Cap34
Moozuki is right. It's a fairly common occurrence.
post #5 of (permalink) Old 11-14-2002, 09:17 AM
Nowhere's Avatar
Replace it, and replace it soon! Your oil has gasoline in it now.. The faulty diaphram lets oil out and gas in!
Also make sure to remove ALLLLLL the old gasket material on the head so the new fuel pump will seat correctly.
Nowhere is offline
post #6 of (permalink) Old 11-15-2002, 05:50 AM
weirdwillie
I had oil leaking from mine and it was simply a clogged PCV system. All of the backpressure that builds up needs to escape somewhere and the vent tube on the fuel pump was the only place. Of course, if gas is getting into your oil due to a broken diaphram (I think this is how my wife got pregnant with our first child!), then you need to replace the whole pump.
