Ring & pinion set up specs - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-13-2002, 07:30 AM Thread Starter
What are the specs for setting up the R & P, and is there any recomended specs for the lock right 1510, Please and Thankyou...This is in a 88.5 Samurai...
tazuki88 is offline
post #2 of (permalink) Old 11-13-2002, 10:01 AM
Re: Ring & pinion set up specs
.004-.006" backlash on the r&p, 4-7lbs torque (rotationally) to turn the pinion shaft at the flange after loading the collar, another 12lbs of torque on the carrier side bearings . 65lbs/ft ring gear bolts. 60lb/ft on the cap bolts, 30lb/ft on the differential cap, locktite on ring gear bolts, cap bolts, diff cap bolts . Lockers setup goes by each man. specs, lockrites use a variation of float on the center block , Detroit uses stack fitment within the diff . Hope this helps,
Sarge
Sarge is offline
post #3 of (permalink) Old 11-13-2002, 10:53 AM Thread Starter
Yes it does and thankyou...
tazuki88 is offline
