Anyone modifyed a pitman arm B4? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-12-2002, 05:46 PM
Wyld_Bill
The pitman arm on my Zook steering box isn't long enough to steer my Zook full left & full right with the Yota axles. SO,...I was thinking of pulling the pitman arm off, cutting it in half on a chop saw, grinding the two halves to a point at the end where it was cut, cut off a piece of 1"x1-1/2" solid square stock, weld the piece of steel between the two pieces.
Anyone else ever done this or a homemade drop pitman arm? This is on a 80% off road rig BTW.
post #2 of (permalink) Old 11-12-2002, 05:49 PM
Re: Anyone modifyed a pitman arm B4?
Yep the sector shaft side is Toy IFS the heim joint sde id stock zuki
rockrat is offline
post #3 of (permalink) Old 11-12-2002, 05:50 PM
pugrocker
[img]images/graemlins/cool.gif[/img] HTH
Here is something that I saw on the spidertrax site
post #4 of (permalink) Old 11-12-2002, 06:39 PM
If you going to make or modify a steering arm do it similar to the calmini arm Pug posted.
BTW many states and provences forbid any welded steering components, and with pretty good reason.
I don't reomend welding 3 pieces like you were suggesting at all. Not even by a "professional" welder,
(Whatever that might mean, I've seen some pretty bad "pro" welders...)
Rockrat's arm looks to be a full lap, so thats not too bad if the welds are done properly.
outlawmws is offline
post #5 of (permalink) Old 11-12-2002, 06:54 PM
daxe's Avatar
yeah..Just ask Ayrton Senna....
[img]images/graemlins/frown.gif[/img]
~daxe
daxe is offline
post #6 of (permalink) Old 11-12-2002, 07:54 PM
Shortwave
Not that I'd advise anyone to do it but......
I've welded a number of steering components, no breaks so far but It's MIGHTY dicey at best.
JMHO,
Shortwave
post #7 of (permalink) Old 11-12-2002, 08:05 PM
Wyld_Bill,
I make custom drop pittman arms all the time for the Tracker/Kick power steering systems since there is not one available. Just take a full size Dodge or Ford pittman arm and lop off the ends with a chop saw. Then weld the Tracker pittman arm ends on. I have built several of them for people we all know.....Whazoo (Robert) and ATV71 (Aaron Kaklamanos)...Aaron even rolled his rig and it held up beautifully. I do not recommend trying this unless you are an experianced welder.
Sean DeVinney
aftermarket4x4 is offline
post #8 of (permalink) Old 11-13-2002, 07:35 PM
Wyld_Bill
Thanks for the replys guys. That Spidertrax one might be the way to go. I wonder if I with a Toyota IFS box would the throw on the pitman arm be better????
are the splines on a tracker box the same as a Samurai???
post #9 of (permalink) Old 11-13-2002, 08:01 PM
The Tracker and Sammi splines are completey different.
88.5 Samurai is offline
post #10 of (permalink) Old 11-13-2002, 11:38 PM
DannyL's Avatar
IFS Toy arm is 6" center to center ands drops about 2.5"
I have an IFS arm that was modified to accept Toy tie rod end.
Tracker one is flat and 5" center to center.
DannyL is offline
