What tire size? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-30-2002, 09:56 PM
jaxondes
What tire size?
So what tire size do you guys think would be best for me?
Its a 94 Tracker 2 dr, it will soon have a 3" calmini lift,k 3" body lift and a header.
Whats the biggest tire I can handle? I'd really like to go with a 31. Can I turn them?
post #2 of (permalink) Old 10-31-2002, 06:49 AM
Re: What tire size?
I ran 31's on my Tracker with stock gears.. it wan't bad at all.. you'll find yourself pulling down outta 5th alot more often.. and off road it's harder on the clutch for sure!
Mini4x is offline
post #3 of (permalink) Old 10-31-2002, 11:25 AM
Re: What tire size?
Take a look.. 1989 2 Door with 33's ... only a Calmini 6 inch Super Articulation kit and a little work to the fenders.. This guy is our buddy in the group.. you can email him at [email protected] .
hcgalvin is offline
post #4 of (permalink) Old 10-31-2002, 11:26 AM
Re: What tire size?
Here's another one.. I forgot to mention that he is still running the stock 5.12 gears.
hcgalvin is offline
post #5 of (permalink) Old 10-31-2002, 12:23 PM
Re: What tire size?
That 89 looks like them 33's don't quite fit.. the front fenders look trimmed down and they still appear to run bad! Maybe just a trick of the pic?
Mini4x is offline
post #6 of (permalink) Old 10-31-2002, 12:47 PM
Re: What tire size?
This is not bad mind you, but for every person on this board, you will find a different opinion. That is not bad, but it does give you a lot of choices. Compare your driving with someone on here that has the same driving requirements or habits and start there. I use my Zuk for a daily driver, hunting and fishing mostly and my setup would not work for a rock crawler. I have a 2" shackle lift and 235's for tires. I am actually thinking of going down in tire size, 225's or 215's. So you have a lot to think about and take your time. Hope this helps.
Good luck,
Jim
JimC is offline
post #7 of (permalink) Old 10-31-2002, 01:53 PM
Re: What tire size?
Well he doesn't have much (if any) of a problem with them rubbing anymore.. and yes, the fenders are trimmed.. as I stated. [img]images/graemlins/smile.gif[/img] I also had to trim my truck to get my 31's to fit.
I can still use 5th gear, more of a cruise control than much else.. but I don't really miss it. She's not a highway truck. The only other issue that I have is that I have to make sure I keep her above 1500 rpm when I am playing around in the dirt.. cause she will stall. Around town though (I deliver pizzas.. [img]images/graemlins/tongue.gif[/img]) she does great. I will be getting gears soon though.
It seems like different people have different experiences. I have heard of people putting 31's on a lift similar to mine, and had no rubbing and less of an issue with speed or hesitation.
Heather
hcgalvin is offline
post #8 of (permalink) Old 10-31-2002, 03:19 PM
Re: What tire size?
Well, Heather, I'm running 31's with the Calmini 6". I had to "hammer back" the driver's side front wheel well. Passennger side never did rub - go figure. Because I live at 9,000 feet elevation, my Kick doesn't have as much power as you do in Idaho, most likely. I DEFINITELY want to regear, and hopefully, my next set of meats will be 33's!
Here's a trick - ZukBoys fender flares for a Samurai will ALSO fit a 2-door Sidekick, and they give you 5" of flare on the outside, and extend 8" INSIDE the wheel well. Just a matter of time, until I get a set. They won't work on the back wheel wheels of a 4-door, because the back doors are so close to the wheel well.
