90 TRACKER-NO HOT WATER TO HEATER HOSES - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-30-2002, 02:21 PM Thread Starter
I following Sarges advice checked the heater hoses and both are cold.I have been running some Prestone 10 minute cleaner in the Tracker for about 4 weeks,I would have thought that would clean out the garbage,guess not.Where would you start the cleaning process.My thought is to drain the cooling system and run water a while to flush out what I can that way.Then air pressure thru the heater core and water pump and return hose port.Any more ideas,Thanks for the HELP,RR
rangerrick is offline
post #2 of (permalink) Old 10-30-2002, 03:43 PM
Re: 90 TRACKER-NO HOT WATER TO HEATER HOSES
Not hot to either one? I suspect if the heater core was completly plugged that hot water wouldn't even flow to the core, but if there is partial flow the supply hose should get warm.
So your plan to flush with straight H2O seems a good place to start and possibly check the external pipe for plugging/clogging. Maybe disconnect the core hoses and try the garden hose through the core to see if you can unclog it.
I suspect you and I will both be pulling dashes shortly to replace cores. Me maybe this weekend.
(But I found a used hard top in my town at the price I can afford so warmer temps for my commute are coming soon!) [img]images/graemlins/smile.gif[/img]
Fastone_84401 is offline
post #3 of (permalink) Old 10-30-2002, 04:07 PM
RR,
The first thing I would do is disconnect both heater hoses at the block. See if there is any flow,
and if so back flush the heater core and hoses. If there is no flow, go through the hoses till you
find the plugged section or pin the prob on the core.
If the hoses/core are clear, you could have a plugged fitting in the block or, we once had a fitting
that extended into the intake and the end had been bent over (BB Ford, might not be possible here).
A hack saw fixed that one!.
outlawmws is offline
post #4 of (permalink) Old 10-30-2002, 06:33 PM
dparker's Avatar
just simple question are you running a thermostat?
dparker is offline
post #5 of (permalink) Old 10-30-2002, 06:54 PM
hmm.. does the Geo have a heater control valve like the sammy.. I don't recall. The heat in my sammy was a no-go and my valve was stuck.
Mini4x is offline
post #6 of (permalink) Old 10-30-2002, 08:24 PM Thread Starter
fastone,when you pull the core,let me know the short cuts.thanks RR
post #7 of (permalink) Old 10-30-2002, 08:26 PM Thread Starter
OUTLAWMWS,I will pull the hoses loose and back flush and check for a plug at the block return port,thanks RR
post #8 of (permalink) Old 10-30-2002, 08:30 PM Thread Starter
Mr Parker,I do have a new 195 thermostat in place.I hear I may be picking up a roll cage for you here in Indiana.If so let me know where it is and its size ,so I will know if I need to remove my camper shell,RR
post #9 of (permalink) Old 10-30-2002, 10:23 PM
dparker's Avatar
i checked everthing on my 91 thought it was gremilin on mine come to find out it always ran real cool NO themostat LOL!!!
Im going to contact him tonight rick well let you no more after i here from him again Thanks .
and BB
dparker is offline
