Re: Need some brake help
I'd check to see if you have a wheel cylinder leaking first , then make sure to bleed the rear bias valve on the frame and re-bleed the rear brakes . Also, if the e-brake actuating arms aren't free at their center joint, the brakes won't be adjusted enough to give you the pedal height you should have . Those arms rust up pretty easily , I've had to heat mine up several times to keep them loosened up . Hope this helps,
Sarge
