chuck the fresh u-bolts for spring replacement? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-29-2002, 09:30 PM Thread Starter
ackerdackerly's Avatar
This may be exceedingly dumb, but do I have to replace the nice and new u-bolts I used on my SPOA when I replace my sagging set of springs?
ackerdackerly is offline
post #2 of (permalink) Old 10-29-2002, 09:40 PM
Re: chuck the fresh u-bolts for spring replacement?
I would think only if you notice a crack or some other flaw. There should be no problem unless you use a thicker set of springs and they become to short.
sky_hi_samurai is offline
post #3 of (permalink) Old 10-29-2002, 09:51 PM
I managed to remove & use all of my u-bolts when I changed my springs a couple weeks ago. I general rule is to always replace hardware, but if it is still servicable, why not use it.
Mort-Man is offline
post #4 of (permalink) Old 10-29-2002, 10:00 PM Thread Starter
That's what I was thinking, Mort.
They are only 7 months old and have less than 3000 miles on them.
I can see junking rusty old bolts with over 100k on them...
post #5 of (permalink) Old 10-30-2002, 06:00 AM
i wouldnt have a problem at all reusin em ack. id say yer good ta go man...
BiLLy bOb
Billy Bob is offline
post #6 of (permalink) Old 10-30-2002, 06:02 AM
Just make sure you re-torque them a few times! Ubolts stretch when you install them and stretch over time some.
Mini4x is offline
post #7 of (permalink) Old 10-30-2002, 06:46 AM
There is a good rule of thumb that applies to u-bolts real well. First, toque them to 30 ft.lbs , then to 60 ft.lbs. as evenly as possible . It's difficult to keep them tight against the spring pad, but with some work or a clamp it can be done . You just want them straight as possible . Do the first torque step on one side , then the other side of the axle . This keeps everything nice and straight . Once the bolts are torqued, here's the rule: Torque the first day , re-torque the next day (after some miles of course) , re-torque after one week , and again after a month . This will keep up with bolt stretch , and ensure that all of them are even . Good luck,
Sarge
Sarge is offline
post #8 of (permalink) Old 10-30-2002, 11:26 AM
Just make sure when you remove them that you first clean the exposed threads real good with a small wire brush (toothbrush size is fine by hand), then put a little oil on them and where the threads go into the nut BEFORE you try to remove them. This will keep you from ruining the threads.
TGT - NCO
NCOffroad is offline
