How do you keep leaf springs in line? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-26-2002, 05:50 PM Thread Starter
MrSurly's Avatar
Hi all. I made my first run at Zuwharrie with the new CJ rears and rears-up-front suspension. There are no bands or clamps around my leaf spring packs, only the u-bolts keep the leaves in line. After a few rides, one of the leaves spun out of line with the others on my front springs. How do I prevent this from happening? Tighten the u-bolts super tight? Put bands around the leaf packs? Ignore it and hope it goes away? TIA
MrSurly is offline
post #2 of (permalink) Old 10-26-2002, 06:10 PM
Carpal \'Tunnel
JIMZUKI's Avatar
Re: How do you keep leaf springs in line?
howdy,
to keep my leaf springs in line I YELL AT THEM. lol but really i ordered so military wraps from a jeep only vendor. works great. i payed about $20 with shipping and all.
JIMZUKI is offline
post #3 of (permalink) Old 10-26-2002, 06:16 PM
I've got the same problem. The bottom leaf on the front pass. spring is sticking out the side about an inch.
88.5 Samurai is offline
post #4 of (permalink) Old 10-27-2002, 07:56 AM
Yankee Tim's Avatar
Sometimes, in a SPOA, when the front pass. side is drooped, and turned hard to the right, the Z-link rubs the springs and moves the bottom leaf. Happened on mine. Took a while before I found out what was happeneing.
Yankee Tim is offline
post #5 of (permalink) Old 10-27-2002, 11:33 AM
Zlink!! I don't use no stinking Zlink!! Breeze Xover for me and Mr.Surly
post #6 of (permalink) Old 10-27-2002, 12:53 PM
When I had a hybrid leaf pack it did the same thing. I didn't find that it inhibited ride quality or performace so I did't worry about it.
Now I have yj's and I just left them all clamped up. The fronts flex just fine clamped the rears on the other hand is a different story. I think that I had more articulation when I ran rears up front, cj's in back with m/l all the way around. Now I have yj's all the way around with m/l just up front. The rear doesn't droop as much as I would like. I could prolly get a couple more inches if I unclamp the springs but I'm getting way too much axle wrap in the rear with them the way they are I don't dare unclamp them. I doesn't matter now anyway, since I'm going to coils in the rear.
Tanzuki is offline
post #7 of (permalink) Old 10-27-2002, 10:28 PM
I Do This For The Glory
JEEPN's Avatar
Use a muffler clamp to get them back into line, and then leave it loose, or a little loose (or take it right off) when you hit the trail. If you put the muffler clamp on now (yes, I know it's rounded), you can tighten it down a little at a time as you drive it and the springs will come back into alignment. If you put it on so it's next to the end of one of the leaves, it'll stay pretty good by itself.
JEEPN is offline
post #8 of (permalink) Old 10-28-2002, 03:06 PM
What you are looking for is a 'rebound clip'.
They are like $1.50 from anywhere that deals with leafsprings. The secret here is to hammer them on tight on the sides but then leave slack or use a rubber piece so they are not so tight on the top and bottom, that way they will still flex well and not get out of line.
post #9 of (permalink) Old 10-30-2002, 06:40 AM
I have seen this to be more of a problem with the leafs that have graphite pads than those that do not. Couple things, the u-bolts should be torqued to 50 ft lbs when the threads are clean and oiled. The king pin should also be wrenched down very tight as well. I have had this occur a few times and used a BFH on the trail to knock it back in line. I didn't have Jimmie available to yell at them for me! Another way that works is to get a 2" square u-bolt from the hardware store, one that has a flat plate on top. With the leafs in line, put the u-bolt on near the end of the offending leaf, with the threaded ends up. Slip the plate over the top, and here is the trick, drop some very stout springs over the threaded ends and tighten them down some with the nuts to provide tension. To keep it in place, I have tack welded it to the leaf on the bottom, a couple tacks near the end won't hurt the spring. These are manufactured and available from spring shops, but most of the time they are flat on the bottom and riveted in place. Sometimes they are just legs that stick up from the sides, take a look at your factory overloads, same thing.
HTH
TGT - NCO
NCOffroad is offline
