90 Tracker- no heat-i deas - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-25-2002, 11:34 PM Thread Starter
I installed a 190 degree thermostat and the heat gauge rarely ever sees the mid-point of the heat gauge.I had luke warm air when I bought it last year and now I have all cold air.Where is the heat control[90 ,1.6 ,8v.tracker].I put in some 10 minute radiator cleaner about 3 weeks ago and left it in and that did not clean out nothing.I thought about blowing air thru the heater core backwards and hope that opens up something.If that doesnot work,how hard is it to remove the heater core,I hope not as bad as my 88 sami.Thanks for the help,RR
rangerrick is offline
post #2 of (permalink) Old 10-26-2002, 04:48 PM Thread Starter
Re: 90 Tracker- no heat-i deas
btt.its cold, any ideas,thanks RR
post #3 of (permalink) Old 10-26-2002, 07:34 PM
I would check the control vavle Rick, Just trace it back
near the firwall. If you need a heater core let me know I have a spare I will mail you.
wildweasel is offline
post #4 of (permalink) Old 10-26-2002, 07:43 PM
Trackers have no control valve that shuts off the water flow, just kills the airflow through it. Getting it out isn't supposed to be too difficult but does require pulling most of the dash. (I'm about to find out for the same reasons you mentioned.
Last winter I did take my air tank and sprayer nozzle and blew through the vent up backwards of the normal airflow to remove the junk that blocks airflow.
I'm also considering adding a 2nd heater core in the place where the ac cooling unit would be if I had one.
You're right, its getting cold on my commute to work!
Fastone_84401 is offline
post #5 of (permalink) Old 10-27-2002, 01:02 AM
Might want to make sure there is no blockage in the heater core. Possible might also be an air bubble in the system causing flow problems thru the heater core.
post #6 of (permalink) Old 10-27-2002, 08:02 AM
Check to make sure the heater hoses are getting hot first . With that done, there should be an air control cable or vacuum control that works the door for heat . Just follow that cable down and verify that the door is moving . Some systems require that one door's movement closes off a second door to make everything work . I'm not real familiar with the Tracker's system , but these are general rules for diagnostics....
Sarge
Sarge is offline
post #7 of (permalink) Old 10-27-2002, 01:19 PM Thread Starter
Thanks Glenn,if I need one I will get back with you,RR
post #8 of (permalink) Old 10-27-2002, 01:23 PM Thread Starter
Hi Glenn of RR,I drilled two small holes in my thermostate to fix the air problems,I think the core is plugged.Thanks for the info,RR
post #9 of (permalink) Old 10-27-2002, 01:24 PM Thread Starter
THANKS Sarge,I will do that.Say hey to the little lady for me,RR
post #10 of (permalink) Old 10-28-2002, 12:42 AM
Might want to make sure the blend door is working properly. I had a simialar problem with my 'kick when I got it, and the little loop on the end of the control cable was broken off. A trip to the local Zuki dealer and $6 later, it was fixed.
dschwab9 is offline
