Reverse Switch & 5th Gear Switch ?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-25-2002, 08:53 PM Thread Starter
CrowHorse's Avatar
Are they interchangeable? I think my reverse switch is toast. I'm not using the 5th gear switch. I'm wondering if I can just swap the two.... I'm not home now to look at a spare tranny.... Thanks!
CrowHorse is offline
post #2 of (permalink) Old 10-25-2002, 11:15 PM
Re: Reverse Switch & 5th Gear Switch ??
Yep, same same....
Sarge
Sarge is offline
post #3 of (permalink) Old 10-26-2002, 06:35 AM
MrSurly's Avatar
Same switch, different connector. That prevents you from accidentally swapping the plugs at the firewall. You'll have to cut and splice the right connector onto the switch wires. Another option is to wire a manual toggle switch on the dashboard to control the backup lights. HTH
P.S. I love the LSD! [img]images/graemlins/cool.gif[/img]
MrSurly is offline
post #4 of (permalink) Old 10-30-2002, 10:16 AM
Thanks for that info. Those switches are a terrible design.
Since Crow doesn't use the 5th switch, it would be possible to wire the two connectors together (at the firewall) so the backup light switch could accept either and still function.
Jim
JimC is offline
post #5 of (permalink) Old 10-30-2002, 10:23 AM
are they the same as the 4wd switch?
also, what is the 5th gear switch for?
thanks
rich_d is offline
post #6 of (permalink) Old 10-30-2002, 04:00 PM Thread Starter
CrowHorse's Avatar
My 5th gear switch had the wires broken off, so I pulled that and the reverse switch from a spare late model tranny. Cut the connector off my harness, and used the connector from the 5th gear switch I scavenged and the "new" reverse switch plugged right into the 5th gear connector (which replaced my original connector). Not sure if this makes sense, but my reverse lights work fine now....
post #7 of (permalink) Old 10-30-2002, 04:35 PM Thread Starter
CrowHorse's Avatar
"P.S. I love the LSD!"
I knew you would!!!!!!!!! The LSD has proved better than I had hoped for in on road driving. I can hardly wait for the white stuff to fall!!!!!!!!
post #8 of (permalink) Old 10-30-2002, 04:41 PM Thread Starter
CrowHorse's Avatar
I guess if I had wired it wrong and while shifting into 5th gear, my reverse lights came on, it would give one hell of a scare to someone following me...
post #9 of (permalink) Old 10-30-2002, 04:45 PM
I guess you will know, when they suddenly slam on their brakes and swerve... LOL
rich_d is offline
post #10 of (permalink) Old 10-30-2002, 04:55 PM
MrSurly's Avatar
>>are they the same as the 4wd switch?<<
>>also, what is the 5th gear switch for?<<
Rich: same switch, different wire length. The 4wd switch wires aren't long enough to make it up the firewall to the connectors. This is why you should always hang on to your wires and connectors after the wires break off of the switches. You can splice the wires onto any good switch.
The 5th gear switch tells the ECM to disengage the EGR system when the tranny is in 5th gear. (If your Zuk is like mine, the EGR system is disengaged all the time!) HTH
MrSurly is offline
