Re: pics of front missing links needed!!!!!
First, you need to clip off the corner of the u-bolt clamp plate on a 45* angle right to the edge of the lockwasher, then round the corners. If you have more than 4" of up travel, then you are going to do more than break the lower shock weld. After you go beyond 4" you are eventually going to kink your springs over the edge of the spring perch. You either have to install a bump stop, or put on a shock with a shorter compressed length as it is now acting as your bump stop and tearing the lower weld off, not to mention the damage it is doing to the shock wiper seal and internals.
HTH, TGT - NCO
