flairs gone - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-21-2002, 09:27 PM
flairs gone
got a couple questions..i took off my flairs and and there a ring around the body that i would like to remove how do i got about doing this it looks like its tack welded on there..
post #2 of (permalink) Old 10-22-2002, 03:45 AM
zooky's Avatar
Re: flairs gone
I used an angle grinder to grind off the spot welds, worked good, took 5 minutes each
zooky is offline
post #3 of (permalink) Old 10-22-2002, 08:19 AM
Yankee Tim's Avatar
Re: flairs gone
Pick up a good spot-weld drill bit.
Yankee Tim is offline
post #4 of (permalink) Old 10-22-2002, 05:31 PM
zooky's Avatar
Re: flairs gone
I had one, went dull fast. Angle grinder is faster but will distroy the flare bracket if you were planning to reuse it
zooky is offline
post #5 of (permalink) Old 10-22-2002, 05:52 PM
Yankee Tim's Avatar
Re: flairs gone
I hear you. The first one we had was turd. It dulled fast and chipped teeth. Got one from Snap-on and it's wayyyy better, and we picked up several extra bits for it. Zip thru the welds in seconds. Took both rocker flanges of my GV in under a half hour. Best to centerpunch the weld first so the bit doesn't wander.
post #6 of (permalink) Old 10-22-2002, 10:36 PM
Re: flairs gone
cool i got a grinder..so what do i do about the hole that throw the body when i pull the flare off it rips holes
post #7 of (permalink) Old 10-23-2002, 02:22 AM
Re: flairs gone
if you grind correctly you won't have a hole.
mykwillisrn is offline
post #8 of (permalink) Old 10-23-2002, 03:45 AM
zooky's Avatar
Re: flairs gone
dont grind all the way through, grind most of the spot weld and then "pop" it off by pulling. I did one or two at a time then ground off the knubs that were left, cant even tell anything was there
zooky is offline
post #9 of (permalink) Old 10-23-2002, 02:01 PM
Re: flairs gone
ok ill try that...thanks
post #10 of (permalink) Old 10-23-2002, 02:25 PM
zukiman
Re: flairs gone
Grinding off the spot welds with an angle grinder works, but it is such slow progress. I started out taking mine off that way, but it was so frustratingly slow. I decided that since my fenders were rusted and needed repairs anyways, I'd just drill through the spot welds and repair the small holes that were left over. That worked much better.
-- Geoff Beasley
