Tach won't work... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-17-2002, 12:11 AM
tintop
Tach won\'t work...
Just got my Zuk running today and the tach doesn't work? Can someone give a few pointers as to what I need to check/test to get it working? Thanks in advance!
post #2 of (permalink) Old 10-17-2002, 01:17 AM
Re: Tach won\'t work...
A little more info might help. Is it a stock tach or an aftermarket install or even a stock tach cluster swap? Most likely it's a loose wire somewhere near the distributor. Seems to me if it's the main harness plug behind the dash more things wouldn't be working also. If it's an aftermarket tach be sure it's connected to the negative side of the dis. on a '94 model this is a brown with white stripe wire.
sky_hi_samurai is offline
post #3 of (permalink) Old 10-17-2002, 07:10 AM
Tintop,
It's a shot in the dark but, the temp gauge on mine would not work and when I pulled the cluster out to check the plug-ins I noticed that one of the nuts on the back was loose. When I snugged it back up it began working again. My problem was that the gauge was not grounded due to the loose nut.
I guess that is just another one of those "loose nut behind the wheel" stories but it is true.
mygreenihc is offline
post #4 of (permalink) Old 10-17-2002, 09:44 AM
tintop
Sorry for the limited info. It's a stock cluster from an 86 JX hardtop. I've had the cluster out and checked for corrosion and loose connections...I found nothing wrong. All of the wiring harnesses seem to be in good shape, but I'll be checking them more thouroughly today. How many wires should there be coming off of the coil? 2-3? I also found a little circuit board behind the cluster that has 4 small diodes on it. The brown/white wire that comes from the negative side of the coil, leads right into this and then some red and red/yellow wires leave the board and re-connect to the harness.....what is this??? Thanks.
