1.3L Starting problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-10-2002, 12:00 AM Thread Starter
The sami runs great, but if I let it sit for more than a day, it takes about 15-25 seconds to start. Its acting like the fuel in the lines and floatbowl evaperates. How do I fix this?
Benny Boy is offline
post #2 of (permalink) Old 10-10-2002, 07:26 AM
Cap34
Re: 1.3L Starting problem
I wonder if there's a check valve somewhere in the fuel line that is supposed to keep the line full. I'll take a look in the manual today.
post #3 of (permalink) Old 10-10-2002, 08:28 AM
Try pushing the gas pedal to the floor 2 or 3 times before you turn er over. That makes the accelerator pump squirt gas into the venturi . If there is any gas in the float bowl this should work---unless the accelerator pump needs rebuilding.
AkDale is offline
post #4 of (permalink) Old 10-11-2002, 09:20 AM
Cap34
Looked through the FSM and did not find a check valve. Sorry.
post #5 of (permalink) Old 10-11-2002, 09:44 AM
The needle and seat in the carb act as a check valve. If the needle and seat are bad. the fuel can leak out of the float bowl there and cause your starting problems.
AkDale is offline
post #6 of (permalink) Old 10-12-2002, 12:56 AM Thread Starter
I guess I will just live with it. The carb runs to good as it is (not quite EFI, but very good) so I dont want to mess with it.
post #7 of (permalink) Old 10-12-2002, 01:53 PM
It sounds as though the fuel is either draining out or evaporating. Any dripping
down the carb throat after shutoff? Does it run on the hot side?
outlawmws is offline
