Axle Seal number or Dimmensions - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-07-2002, 12:07 PM Thread Starter
This could be a long shot but I was wondering if anyone could give me the seal number or dimmensions for axle seal. The seal that keeps the diff oil from seaping into the nuckle.
Thanks
Lil_Mudder is offline
post #2 of (permalink) Old 10-07-2002, 06:48 PM
MrSurly's Avatar
Re: Axle Seal number or Dimmensions
SGP number 09283-26016 [img]images/graemlins/cool.gif[/img]
MrSurly is offline
post #3 of (permalink) Old 10-07-2002, 06:56 PM
Here are a few parts numbers and links that I have accumulated.
Bearings and seals for diff.
2 side bearings # BR17887
1 inside pinion # BR30307
1 outside pinion # BR30306
1 pinion seal # 350572
The bearings are SKF and the seal is Federal Mogul
This kind of info and a lot more can be found on:
http://groups.yahoo.com/group/offroadtech/
86-88 Bearing, front wheel Suzuki 09265-41001 OEM P/N
86-88 Bearing race, front Timkin LM300811
86-88 Bearing, front wheel Koyo Hi-Cap (Japan) 57414 Original from Suzuki.
86-88 Bearing, front wheel Automotive Bearings International (Timken) LM300849
Marked with two part numbers, for bearing and race.
Both inner and outer front wheel bearings are the same.
86-88 Bearing, rear outer axle wheel Koyo (Japan) DG3572DWRKB Original from Suzuki:
note this is the bearing only and does not include the retainer ring.
86-88 Bearing, rear outer axle wheel Federal Mogul RW128R Includes the retainer ring.
Federal Mogul is available from Industrial Bearing.
Rears are: SKF brand # 6207 2RSJEM, $27.71 at Kaman Bearing in Nampa
Fafner brand are the same but only $20.70 ea
Longer brake lines. Ours are from a Honda Accord. At 26 inches
Longer brake lines
NAPA numbers... I think this is for the front... # 38673
And this is for the rear... # 38688
Price here in town for them was $29.99 (each) for the front a
nd $19.49 (each) for the rears
T case shifter sheet
The Suzuki part number is 29541-80051.
I bought two (one for a spare) in April 2001 at my
local Zuk dealer for $8.46 each plus tax.
Here is what is on the box of Wheel stud's I got from NAPA. (stock size)
Balkamp. # 641-2187
Size M12 DIA X 37.5 MM
Distributor O-Ring
OK heres the specs on O-ring get one at any parts store
width 3/32
Inner. diamenter 2-3/16
Outer diameter 2-3/8
the widht is just wee bit bigger than stock to make a better seal
Here's the list of part numbers I have for longer brake lines.
Also, Geo Metro lines are supposed to do the trick! :
Part Maker part #
Front Longer Brake Lines napa 38541
Front Longer Brake Lines raybestos bh38541
Rear Longer brake lines napa 38688
Rear Longer brake lines Wagner f 120870
Rear Longer brake lines bendix 78351
Rear Longer brake lines raybestos bh38688
Ford front shock towers (weld on BTW)
part # E5TZ-18183-A
I've got some Gabriel Gas Ryder LT VST's and they are LONG!
Get them at AUTO ZONE Part number Gabriel/springfi G63438
They are 19.99 each and measure out at 31" extended and 17.5" compressed!
Not too bad.
The shock tower is the Ford one, they are super long and there part number is:
E5TZ-18183-A
Rear disk brake conversion.
You have to get the right years.
Other wise the disc is a different thickness.
I think it's 81&82 Subaru sedan (mine are 81 GL 4 Door).
You also want the cables and the bracket that hooks to the e-brake handle.
There is a cable on both calipers.
Samurai rag joint, part #
Suzuki # 48251-52000
Aftermarket red HELP package # 31002
Spicer u-joint (Dana Corp)5-1503X
GMB (Kragen/Checker) #6181721
Brass Tip Dist Cap Borg Warner Select #C605 Rotor # D571
(also goes under NASCAR Brand at ADVANCE AUTO)
Alt motor mounts 318 Plymouth Valient (1974) #602265 Pioneer
Replacement antenna RALLY # 3364
http://www.off-road.com/suzuki/samurai/samparts.htm
http://www.off-road.com/suzuki/samurai/samafter.htm
AkDale is offline
