1.6L throttle body / EFI work with samurai harness - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-07-2002, 11:34 AM
pugrocker
Will a 1.6L throttle body / EFI and intake manifold from an 89-90 Kick work properly if plugged into 1994 samurai factory harness? Can I just keep the stock harness and use the ECM from the kick?
post #2 of (permalink) Old 10-07-2002, 11:41 AM
pugrocker
Re: 1.6L throttle body / EFI work with samurai harness
....and if I can't use the 1.6L throttle body / EFI from an early model kick with a late model Samurai harness - I am assuming that I can use the 1.3L EFI setup on the 1.6L block?
post #3 of (permalink) Old 10-07-2002, 11:56 AM
Either way sound like trouble to me...Ill sell ya my 94 motor w/ cam and EFI...It needs rings...Burnin some oil...But still better off than what You are heading for Me thinks...
Tkat2K is offline
post #4 of (permalink) Old 10-07-2002, 02:33 PM
If I remember corectly the whole efi 1.6l motor; intake, tb, and block, will still be efi in an efi sami, using the sami harness and ecu. I had a donor tracker that I was goin to do the same thing, in my efi sami, but chose not to now that I have the swift gti donor, that I'm workin on puttin in my sami. Anyways I have been told that the tracker ecu's will work on stock efi samis, that being said it is already programed to run a 1.6, so your efi 1.6 will run just like it should in the sami, if you plug in the tracker ecu. There is a small power loss on the 1.6 when running the sami's ecu (programed for a 1.3) so you would be in good shape. Good luck, hope this helps, -Drew
P.S. This info is for an 8 valve, just so you know. I'm guessing you have access to a whole 1.6 motor, correct?
Drew is offline
post #5 of (permalink) Old 10-08-2002, 07:36 AM
Yankee Tim's Avatar
I think Zooky said that the plugs were the same, so it should swap in.
BTW - much better pic in your tag.
Yankee Tim is offline
post #6 of (permalink) Old 10-08-2002, 09:05 AM
pugrocker
I will be picking up a 94 rust-free samurai and I want to swap everything from my 88-1/2 onto it (suspension, transfer case) and my 1.6 Valve motor but do not want to rewire everything (again). Ideally I would like to use the 1.6L block, intake manifold and throttle body setup and just plug it in to the Samurai's stock ECM......will it work?
post #7 of (permalink) Old 10-08-2002, 09:20 AM
Brown29's Avatar
Pug, I'd plug the 1.6 ECM into the Samurai harness and it should work fine. I think the plugs on the 8v are compatible with the EFI 1.3 and using the correct ECM would allow the engine to get the proper fuel and air mixture. There's only a couple of screws mounting the ECM under the dash so it is not much trouble to swap.
Brown29 is offline
post #8 of (permalink) Old 10-08-2002, 09:28 AM
pugrocker
....do you think the Samurai ECU will work OK with this setup or should I just use the Kick ECU??
post #9 of (permalink) Old 10-08-2002, 11:08 AM
Yankee Tim's Avatar
I'd try the one for the kick
post #10 of (permalink) Old 10-08-2002, 11:58 AM
Brown29's Avatar
I agree with Tim. The 1.3 ECU may work, but the computer is programmed based on the parameters for the 1.3 engine's fuel and air requirements. I would guess the performance would be less than optimal.
Brown29 is offline
