Stripped Tranny Drain Plug - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-20-2002, 01:15 PM Thread Starter
Well the votes are in.. The guy that owned my current Sammy before I did was a complete idiot. I went to change the tranny fluid and saw the most disgusting display of a drain plug I have ever seen I tried fitting the usual socket into it but of course there was too much play and it was way to tight. The harder I turned the more it started to slip.
Any ideas.. Cause I need a good one!
[img]images/icons/frown.gif[/img]
Lil_Mudder is offline
post #2 of (permalink) Old 09-20-2002, 01:24 PM
HankS
Re: Stripped Tranny Drain Plug
Sounds to me like you need to get familiar with a tap and die set. Aluminum is easy to work with...
Hank
post #3 of (permalink) Old 09-20-2002, 01:26 PM Thread Starter
What is it and where can I get it
post #4 of (permalink) Old 09-20-2002, 01:42 PM
If you have access to a welder you can always tack another nut on the bottom of the drain plug.
I've done this with other rounded off bolts and it works well.
Maybe someone else can confirm that this will not do any harm to the tranny case itself. I don't think it would harm anything as long as you tack it quickly.
mmartian1969 is offline
post #5 of (permalink) Old 09-20-2002, 02:19 PM
Tack is the Operative word. As long as you don' put a ton of heat into it you should be fine. I have done this on Motorcycle cases too.
wildweasel is offline
post #6 of (permalink) Old 09-20-2002, 02:27 PM
Is this an external hex or an allen? If its external you can get a good set of vize grips on it.
outlawmws is offline
post #7 of (permalink) Old 09-20-2002, 02:44 PM
TACK weld a bolt to it---Weld the threaded end inside the 3/8 square hole. WAIT till the plug completely cools before trying to remove. Remember, Steel expands when hot. Let it shrink back or it will bind. If it is still hard to remove, Heat case--not drain plug with a propane torch. Dont heat it too much. then try to remove it while the case is hot.
AkDale is offline
post #8 of (permalink) Old 09-20-2002, 03:56 PM
HankS
I'm sorry man, I re-read your post. Your not turning the plug inside the t-case (stripped threads), the plug is stripped. DUH
I agree with the above, weld a bolt on it... or use a set of robogrips, or vice grips. I have ground down opposite sides of a bolt and used pipe wrenches on stubborn bolts in the past and had good luck with it...
post #9 of (permalink) Old 09-20-2002, 04:45 PM
This has happened to me before. I ended up using a pair of brand name "Vise Grips" and put it nice and tight and then tapped it with a hammer.
4x4_Austin_Mini is offline
post #10 of (permalink) Old 09-22-2002, 11:47 PM
same thing was wrong with mine
there was enough sticking out that I was able to use the hammer and chisel method.
Murph
Murph is offline
