Mystery oil leak - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-18-2002, 08:44 AM Thread Starter
Mystery oil leak
I have an 87 with an oil leak that it can't pinpoint. It appears to come from the area around the distributor or the rear of the head. I can't find a point of origin. I go through a qt. of oil every 50 miles! Due to this, I would expect to see a steady drip while the engine is running, but don't see one.
Also, I suspect the O2 sensor is bad. I sometimes hear a knock while I am accelerating, but not all the time. Prior to the knock I replaced the plugs, wires, rotor and cap, and checked the timing. Also replaced the restrictive breather box for a K&N conical filter, all of which increased mpg about 4.
Could the sensor be the problem or is there something else causing it?
All input is appreciated
Nuttman1 is offline
post #2 of (permalink) Old 09-18-2002, 08:53 AM
pugrocker
Re: Mystery oil leak
try this http://www.petroworks.com/leaky_distributor.htm
I have to do it myself......I get little puddles of oil everywhere I park and I am pretty sure it is the disty - just haven't had a chance to change the O-Ring yet.
post #3 of (permalink) Old 09-18-2002, 09:23 AM
Dude... Nutman.... I'm beginning to think you stole my truck.
EXACTLY the same probls I'm having.
lets put our heads together and fix em both.
Murph is offline
post #4 of (permalink) Old 09-19-2002, 11:03 PM Thread Starter
Murph
Pugrocker sent me this link.
I think that it should help both of us. Doesn't look like it takes too long either and the cost of two O-rings is cheaper than a qt. of oil.
Nuttman1 is offline
post #5 of (permalink) Old 09-19-2002, 11:05 PM Thread Starter
Pug,
Thanks bro! I figured that it would be harder than it is. I will do it tomorrow.
Nuttman1 is offline
post #6 of (permalink) Old 09-20-2002, 06:33 AM
MrSurly's Avatar
Nuttman (and others) who are doing this fix: DO NOT use generic o-rings from NAPA or a hardware store! Use OEM SGP o-rings. Other o-rings are too thick, and when you tighten down the housing bolts you will crack the housing. (Ask me how I know this!)
MrSurly is offline
post #7 of (permalink) Old 09-20-2002, 09:24 AM
dcbenj
I couldnt find a fact o-ring so I used the red perm a flex sealant. Hasnt leaked since. just a thought.
post #8 of (permalink) Old 09-20-2002, 09:33 AM
Go to your local GM dealer and get a O-ring for a 1.6 8v track/kick. It is the same as the 1.3. Cost a about a $1.
sky_hi_samurai is offline
