starters? do they interchange? got one? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-15-2002, 12:16 AM Thread Starter
i have a fuel injected 1.6 8valve. will a samurai starter work on this sidekick engine? anybody got the one i need?
badzuki is offline
post #2 of (permalink) Old 09-15-2002, 08:07 AM
Re: starters? do they interchange? got one?
They do not interchange. Sorry !
ZOOK94 is offline
post #3 of (permalink) Old 09-15-2002, 11:13 AM
i beg to differ
brad yes it will work but you have to grind it just a bit,
also almost everthing from the 1.3 will work on a 1.6
so if you want to run a v-grove belt you can
if you have any questions i have some pics
GA_ZUKI is offline
post #4 of (permalink) Old 09-15-2002, 01:48 PM
Another related quetion. will the 1.3 and 1.0 starters interchange? Surely our northern brethren will know this?
outlawmws is offline
post #5 of (permalink) Old 09-15-2002, 03:43 PM
CrowHorse's Avatar
Where exactly must it be ground down?
CrowHorse is offline
post #6 of (permalink) Old 09-15-2002, 04:02 PM
all i know is that it is on the starter closest to the block
it's not my zuk so i really do not know (sorry)
abuddy was sold a rem 1.3 block and when he got it home it was a rem 1.6 16v block for 200.00 (what a score) so he took everthing from his 1.3 and put it on the 1.6. he had to get a 1.6 time belt and top and bottom timing gear he cut the 1.3 cover to make it fit. and i cut and welded the oil pick up for him and he gutted the 1.3 oil pan. on the crank pully you can only use the one hole and have to redrill the others i would sujest the 1.6 idle pully inside but add a lil spring and the 1.3 will work
GA_ZUKI is offline
post #7 of (permalink) Old 09-15-2002, 04:08 PM
monty
A starter off a f10a will not go on a g13 motor sorry .
Monty
post #8 of (permalink) Old 09-15-2002, 06:12 PM
Skip
Just did this adaptation with a friend. Put in the 1.6 with 1.6 head. Used the 1.3 flywheel, starter and V pulleys. You can either grind the starter or the 1.6 block. I recommend grinding the block. Then if you eveer have to change the starter, it's a 10 minute swap. If you grind the starter and it goes bad in the future better hope you're at home or somewhere with a grinder. Where to grind? It's a trial fit
post #9 of (permalink) Old 09-15-2002, 08:23 PM
dparker's Avatar
ive put 2 starters off 1.3 carbed motors right on 1.6 fi trackes without haveing to do any7 mods if you would like pic i can get 1 for yoo seeing how its right out side
dparker is offline
