Transfer case problems - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-02-2002, 08:10 PM Thread Starter
One of my friends just bought a 91 zuk for $750. When he tries to shift into anything other than 2wd the shifter gets stuck, we drained the fluid yesterday and it was milky white. Also the tranny has trouble down shifting. Im new to the zooki world so i was just needing some help. Thanks
<a target="_blank" href=http://www.mychevytruck.com/showownerpic.asp?u=3274&amp;n=77633&amp;pos=1&amp; album=6487>http://www.mychevytruck.com/showownerpic.asp?u=3274&amp;n=77633&amp;pos=1&amp; album=6487</a>
97tealZ71 is offline
post #2 of (permalink) Old 09-02-2002, 09:11 PM
Re: Transfer case problems
You probably have water in the gear box's. drain and change using cheap stuff, run it a distance to heat it up and drain and change again. Then start looking for how the water got in. Probably the vents, Someone took it swimming. If the gear box's are like that check the diffs too.
as for thre shifting problem it sounds like the shifter sheets (the shifter sheets are shaped dounuts that center the shift lever, nothing sheet like about it.) in both cases. Sami gear box's are notorious for wearing them out, but its an easy cheap fix.
outlawmws is offline
post #3 of (permalink) Old 09-03-2002, 09:34 AM
here is the shifter sheet picture. it is the green dognut at the end.
rich_d is offline
post #4 of (permalink) Old 09-03-2002, 12:00 PM
SuziCrazy
I had the same problem when I bought one of mine.. in my case it was that the shifter was removed (don't know why?)and when it was put back, it wasn't lined up with the gears, so I had to manually align the gears (using a long flat screw driver) then placed the shifter back in....
works fine now...
Just another option!
