head gasket - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-31-2002, 02:28 PM Thread Starter
head gasket
Well i guess i should start from the begining. I just rebuilt my engine. bord .30 over. Well every time i run it its been over heating. So i pulled out the engine again. pulled the head and every thing looks good. My question is, The head gasket looks like it restricts coolant flow threw the cooling passages. the holes in the head gasket are small round holes but in the head and block the cooling passages are much larger. Do you guy think it would be a good or bad idea to open up the holes on the head gasket, to allow better coolant flow or not? and also theres a round hole in the front and back of block on the right side of the engine and the gasket hole is barly lined up what are these two holes for? thanx.
YOTA is offline
post #2 of (permalink) Old 08-31-2002, 04:00 PM
ackerdackerly's Avatar
Re: head gasket
Those two holes at the end of your post are the oil passage holes. If you accidently flip over the gasket and install it upside down, you'll cut off oil flow to and from the head.
I don't see any reason why you could not carefully make the water passage holes in the gasket match the shape of head passages with an exacto-knife.
Or you could look for a better-quality gasket.
ackerdackerly is offline
post #3 of (permalink) Old 08-31-2002, 04:42 PM
Re: head gasket
if you get the water flowing thru the engine too fast it will run hotter..... cause the water dont have time to pull the heat out
post #4 of (permalink) Old 08-31-2002, 04:49 PM
Re: head gasket
The arguement that it flows to quick to cool is an old one. Some people say that if you pull the thermostat out it will actually make the motor run hotter cause the coolant isnt forced to stay in the radiator. But IME whenever I have pulled the thermo it has ran much cooler. Kinda like a river, where ever the water is moving at a good clip it always seems to be colder, but a good swiming hole the water is barely moving.
Anyway I would cut the holes out carefully or like suggested above it may be better to get a higher quality gasket.
Samurai202 is offline
post #5 of (permalink) Old 08-31-2002, 05:54 PM
Re: head gasket
As you've already "crushed" that gasket when you torqued it down the first time you installed it, it might be wise to replace it anyway.....I would.
Mort-Man is offline
post #6 of (permalink) Old 08-31-2002, 06:11 PM Thread Starter
Re: head gasket
Well the one that was on it was from HAWK, and the one i'm about to put on it is from asian auto parts, there both pretty good quality.
YOTA is offline
post #7 of (permalink) Old 08-31-2002, 07:38 PM
Re: head gasket
"if you get the water flowing thru the engine too fast it will run hotter..... cause the water dont have time to pull the heat out"
Well, I guess if you carried that logic a little further, if you restricted the flow even more it would run cooler yet. Makes no sense to me.
The rate of heat transferance is directly proportional to the rate of flow. In other words, the greater the flow of coolant, the cooler the engine.
Farther is offline
post #8 of (permalink) Old 08-31-2002, 08:29 PM
Re: head gasket
It may not be in the head gasket its just possible a lower bearing has spun which would cause the motor to overheat
talking form exp. you may want to look at the lower end. as far as water flow thats )@*[email protected] if that were true you wouldnt need a radiator!
rockrat is offline
post #9 of (permalink) Old 08-31-2002, 08:47 PM
Re: head gasket
The problem with water flow, is not flow thru the engine, but thru the radiator. Too fast and it doesnt cool enough. Too slow and the engine water gets too hot. Its called balance. Radiators usually don't have a ton of extra capacty.
Also if you remembr basic physics hett flows to cold, not the reverse. So it's harder to cool than to heat. apply that logic to each element of your cooling system and you will see better how it works.
outlawmws is offline
post #10 of (permalink) Old 08-31-2002, 09:53 PM
Re: head gasket
thats what I was trying to get at in not so many words I just dont beleive it is a coolant problem caused by the head gasket
It could be as simple as a bad radiator cap, no pressure = the posability of boil
rockrat is offline
