What's the story with this Weber carb? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-29-2002, 09:50 PM
Indy
What\'s the story with this Weber carb?
My 87 'zuki is cutting out on the interstate, she just doesn't wanna run 65. It feels like a fuel problem. Are these Weber carbs legit? What kind of RPM's should I be running at on the interstate? Any ideas on what else could be causing this? It's somewhat of an intermitent problem. Thanks
post #2 of (permalink) Old 08-29-2002, 10:01 PM
Re: What\'s the story with this Weber carb?
Wow..I have a similar problem. Mine will run like a scalded cat (well as scalded a cat as a samurai can be) and then suddenly start bucking and coughing and not want to pull over 3500 (45-50mph) in 4th. I plan on changing the fuel filter but I really don't know what it could be, as internittent as it is
post #3 of (permalink) Old 08-29-2002, 10:01 PM
Check your fuel filter and fuel pressure. You could also have an obstruction in the lines. Try back blowing it back to the tank. if you cant do it with lung power somethings wrong. If all this checks out, check the float level.
outlawmws is offline
post #4 of (permalink) Old 08-29-2002, 10:03 PM
Float level, too high or too low? I've been playing with mine so I wondered if that might be it
post #5 of (permalink) Old 08-29-2002, 10:05 PM
Samiam, in your case, check you dist and bat cable grounds to the firewall. Clean tight and brite, is the rule, but also make sure the wires arn't failing. My dist ground got down to 4-5 strands and was intermitant as heck.
post #6 of (permalink) Old 08-29-2002, 10:08 PM
If its the float, it will be too low, and you would run out of fuel faster that it can be pumped.
post #7 of (permalink) Old 08-29-2002, 10:08 PM
Cool will do, my cables should be replaced honestly, you can see the blue corrosion starting inside the wires on the battery.
Dumb question, where on the distributor does the ground wire come off?
post #8 of (permalink) Old 08-30-2002, 01:20 AM
Pooh-Bah
DougO's Avatar
well, there is the carb extension piece that was a fix for a flat spot. Next time it happens, and your going straight, quickly shut off then turn back on your engine, see if it still does it(as long as its safe).
DougO is offline
post #9 of (permalink) Old 08-30-2002, 04:05 AM
you might wanna try an elec. fuel pump... thats what i run... i've heard the stock pump wont keep up with a weber
post #10 of (permalink) Old 08-30-2002, 06:25 AM
ackerdackerly's Avatar
< Dumb question, where on the distributor does the ground wire come off? >
You should see a black wire with a snap-connector attached to one of the three bolts that holds your distributor on the head. The other side of the snap connector (both pieces are usually black colored) is fastened to the firewall with a bolt.
ackerdackerly is offline
