Cabt find the post, 88.5+ bolts to yota shafts? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-25-2002, 07:28 AM
mikrosilakhan
I swear i saw that the Large flange "some 88.5" and all 89+ bolt directly to the yota shaffts. ANyone know for sure? If so im in the market for a front and rear t-case output ,large flanges..
Thanks !
post #2 of (permalink) Old 08-25-2002, 10:26 AM
Re: Cabt find the post, 88.5+ bolts to yota shafts?
No, they dont, but its the best fit. You clock the bolt pattern 45 deg and redrill. I belive I heard that the Yota flange needs the alignment shoulder trimmed in a lathe slightly. Cost should be minimal, any competent macinest could do it.
outlawmws is offline
post #3 of (permalink) Old 08-25-2002, 11:01 AM
mikrosilakhan
Oh becuase the large flange has enough area to redrill i suppose.. I held it upto my small flange and it would be super weak if drilled. Cool i get it [img]images/icons/smile.gif[/img]
post #4 of (permalink) Old 08-25-2002, 07:04 PM
Carpal \'Tunnel
JIMZUKI's Avatar
howdy,
here is the install notes. and oh yes it can be done, and works great. <a target="_blank" href=http://www.izook.com/tech/toyotadriveshaft_installation.htm>http://www.izook.com/tech/toyotadriveshaft_installation.htm</a> hope this helps
JIMZUKI is offline
post #5 of (permalink) Old 08-25-2002, 08:36 PM
zooky's Avatar
dont mess with the Toyota driveshaft alignment shoulder. I put a sanding drum in my drill press and took my sammi flange and opened up the hole enough for the driveshaft, took like 3 minutes
zooky is offline
post #6 of (permalink) Old 08-26-2002, 08:59 PM
Yes the bolt pattern and size is the same. If you are bolting a sami shaft to a toy axle the centering hub will not center the driveshaft correctly (not a real big deal). If you are bolting a toy driveshaft to a sami axle you will need to either turn down the hub on the driveshaft, or drill out the flange on the rear end.
