mounting doetsch shocks - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-24-2002, 06:53 PM
I installed yj suspension on my samuri. Does anybody know if you can mount the doetsch shocks upside down? Maybe somebody knows how I can install them right side up without having interference from the brake lines and "E" brake cable.
post #2 of (permalink) Old 08-24-2002, 09:11 PM
Re: mounting doetsch shocks
I called Doetsch and asked this very question. They said their shocks work equally as well with the piston up or down, it don't matter.
-G
post #3 of (permalink) Old 08-25-2002, 12:47 AM
I can attest to that, I run them upside down in the rear. The ride feels a little better to me.
post #4 of (permalink) Old 08-25-2002, 06:31 AM
mikrosilakhan
CRAP!!! your kiddin me!! Figures after i mounted the "right side up" so to speak KNOWING it was gonan hit the spring pad alittle amking dents in them [img]images/icons/frown.gif[/img] Oh well, live and learn.. I knew i shoulda asked about that lol
Actualy now i think about it i can turn them around and upside down to hide the dents.......... Wait what am i saying.......... look at my sami lol
post #5 of (permalink) Old 08-25-2002, 11:02 AM
I mounted mine right side up the shock just touched the spring at full articulation untill i broke the panhard bar now they have dents but they are now upside down so they have alot of clearance they get closer to the spring as they extend on my fronts
szki272 is offline
post #6 of (permalink) Old 08-25-2002, 11:17 AM
mine are upside down too. I have shock hoops, rear springs up front and I still had to cut the bumpstops down to make them work. They have a few dents in them form "test fitting" but they work fine.
Capn_Crunch is offline
post #7 of (permalink) Old 08-25-2002, 11:51 AM
At the recent Suzukis on the rocks, Brent from Trail Tough told me it would be better to run the DT shocks right side up, do to there valving. Running them upside down causes the fluid to foam eaiser and lower shock performance. I did notice a big difference by the end of the trail(all of my shocks are inverted) The zuk was way to soft. I'm flippin' mine back over....my.02
zuk88 is offline
post #8 of (permalink) Old 08-25-2002, 12:49 PM
As far as the shock mounts go, I made some lower mounts for mine and was able to clear the brakelines and the ebrake cable.
I used 2x2 angle iron about 2 inches long. I took some shock mount bolts that came with some Procomps I used to have. I cut the bolt and welded it onto the angle. Then welded the angle to the lower back edge of the axle tube. It puts the shock just behind the axle tube and only hangs down about 1/4" below the tube.
mmartian1969 is offline
post #9 of (permalink) Old 08-25-2002, 10:10 PM
Journeyman
SAFARIKICK's Avatar
zuk88 is right. my friends shocks foamed up. the first 1 inch of travel,the shock was useless! This was on OKEZUKI`S rig.
SAFARIKICK is offline
