how much can a t-case be "clocked"? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-22-2002, 09:42 AM
how much can a t-case be \"clocked\"?
how much can i "clock" a sami case? can i make it almost verticle? or all the way verticle? with the front input/output inline? i'm stillplaying with an idea...the main thing i am worried about it oiling capabilities when it's clocked...
thanks
greg
post #2 of (permalink) Old 08-22-2002, 10:16 AM
Re: how much can a t-case be \"clocked\"?
I don't see an issue, as long as you have the same "virtual" fill level. Clocking it usually means a change in effective fill level. Higher and you will probably blow seals and/or spit out the vent. Lower and you burn it up. Hmmm, the vent. You may need to plug and move the vent depending on what the clocking indcates.
outlawmws is offline
post #3 of (permalink) Old 08-22-2002, 11:03 AM
Check with Doug Parker, he clocked one of his to pair them up
post #4 of (permalink) Old 08-22-2002, 12:44 PM
what i would is essentialy just "pivot" the front out flange down so the instead of it looking like this / it would look like this | .i am thinking it would work, just want to make sure.
greg
post #5 of (permalink) Old 08-22-2002, 12:50 PM
greg - you looking to replace a 720 style case with a zuki case? (trying for lower lows?) I've run both setups int eh Niva, and 'yes' the case can be clocked. As mentioned, fill, dran, and vent plugs become an issue - I just made sure the case was sealed, and did a complete drain/fill w/ a measured amoutn of fluid.
only thing to watch would be that high range drops with the low range gearsets. going to some of the 6:1 cases, for example, will put high range down close to the stock 720's low range ( 1.81:1 high on the Sumo 6:1 I believe, while the 720 case is 1:1 high, and 2.12:1 low) in my case, it meant I couldnt use any of the Zuk cases with my diesel conversion.
chris
wanderer4x4 is offline
post #6 of (permalink) Old 08-22-2002, 01:14 PM
would you mind e-mailing me off list?
thanks
greg
[email protected]
post #7 of (permalink) Old 08-22-2002, 01:20 PM
i have figured out my MPH using the different gear sets and such and i should be OK with the 4.16 sets. i can run 4000 rpms at 67 mph, and i only really need to go 55 mph, so i should be fine with that. since it is in my nissan, i already have the stock "married" case and i want to swap out the second divorced case i put in there. that's the plan anyways.
greg
post #8 of (permalink) Old 08-23-2002, 06:14 PM
Greg - sent you a message direct, but I seem to be having intermittent problems with my ISP - if it doesnt show up, you can always shot messages to me via the private message function of the BBS.
chris
