? GM alt. not holding up? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-09-2002, 09:28 AM Thread Starter
Hey,
This is my third GM alt. in two years on my zuk. Is this normal?
All have quit working, the bearings were good in them, the belt was not to tight just a normal chevy 78 amp alt.
On the rebuild paper work it shows the alt. putting out73 amps at 4,000rpm.........hum.....the chevy engine the alt was made for runs about 2,500 rpms at 60mph .
My zuk runs about 4,000rpms at 60mph
Do you think I'm wearing out the alt because it wasn't meant to run at 4,000rpms all it's life?
The zuk is my daily driver so it's always at 4,000rpms in fifth gears
DOABLE is offline
post #2 of (permalink) Old 08-09-2002, 10:15 AM
freebird01's Avatar
Re: ? GM alt. not holding up?
double check to make sure your wiring is correct...did you do anything goofy with it? like jumpstart another car? i did that and fried the diode in mine....twice...these chevy alternaters are very senstive to voltage spikes....a bit too much voltage and BAM (like the emril impression? lol) there goes the diode or the regulator...
freebird01 is offline
post #3 of (permalink) Old 08-09-2002, 10:22 AM
the first one i had i burt up in 3 months it would never stop charging
but the second one was fine when i did the engine swap it had 3 months on it but it cycles
i have not put it on the 1.6 yet and might not still dont know
GA_ZUKI is offline
post #4 of (permalink) Old 08-09-2002, 10:23 AM
Are the diodes, or brushes dying? What is its output voltage? How about under load? Is the regulator doing its job right?
You need to look at the stock chev pullys and what you have now. The pullies are not near a 1:1 ratio, and the zuk has a different crank pully dia. to boot. Actually the alt should be spinning way faster than the motor, but that doesn't mean its right. You might be in the ballpark, or it could be over or under reving the alt for long life. That alt should last for 100K miles without too much problem. Time to do a little math.
Also what is its operating enviroment? hot and dusty? burried in water a lot? Are you in a heavy rainy area like parts of Oregon/Washington?
outlawmws is offline
post #5 of (permalink) Old 08-09-2002, 11:53 AM Thread Starter
Thanks for the replies the pully diameter is the same as on the samurai alt.
Both times it has been the dio trio that failed, The first time after using my warn winch to pull out my brothers FJ40(that thing is sooo heavy) the alt failed.
The next time out of the blue I turned on all my off road lights ( like I've done many times before) pooof no more out put.
Haven't sunk the zuk in a while , It's hot where I live but It's hot everywhere,and yea we get a shower just about every afternoon .
Don't know if this has any effect on the preformance of the alt?
DOABLE is offline
post #6 of (permalink) Old 08-09-2002, 07:53 PM
dparker's Avatar
Heat kills the didoes in chevy alts. If the place your getting the rebuilds at are using cheap rectifier packs it will happen over and over .
dparker is offline
post #7 of (permalink) Old 08-09-2002, 08:26 PM
I fried 3 in one year! I don't abuse the Sammy's charging system like I do in the Chevy(large sound system). The current unit has been working for 9 months, The only change I made was moving the 10 ga. wire that plugs into the back, from the stock plug to the charging post. Before it was slightly over charging. Now it runs about 14.7V.
I figured the ratio of the 1.3 vs. small block rpm's to be close to the same.....the pulley on the Chevy is like 2" larger, making the alt. spin faster @ lower rpm.
I now use Rotational Dynamics' underdrive pulley, so it spins even slower.
The biggest problem I've had is the bracket I got from RRO. No matter what I do, the alt. works its way loose. On my last trip to Sacramento, the bracket broke in half! The bracket looks beefy, but the alignment tabs create fracture points.
crazycooter is offline
post #8 of (permalink) Old 08-09-2002, 09:14 PM
It's possible you've got too much voltage drop on the output wire causing the regulator to have to output more current. For 70 amps, you need at least 6ga wire, and 4ga would be better. The factory zuk wire is probably only 10ga, which is only good for 30-35 amps - about what the stock alternator supplies.
If you're still using the stock wiring, I would run a 4ga wire from the post on the back of the alternator straight to the positive battery terminal.
I don't think RPM issue is your problem. If it were turning too fast, you probably would be loosing bearings and not electrical components.
dschwab9 is offline
post #9 of (permalink) Old 08-09-2002, 09:37 PM Thread Starter
Good point I'm using 8ga from the alt. to the battery(+) Fine strain cable
"I don't think RPM issue is your problem. If it were turning too fast, you probably would be loosing bearings and not electrical components"
I didn't even think about looking at it that way...damm this board is good [img]images/icons/smile.gif[/img]
DOABLE is offline
