gear install - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-09-2002, 02:18 AM Thread Starter
gear install
im sure this has been posted before but i really need a detailed write up on installing ring and pinions in my sammy. im rebuilding the rear end so a write up on how to do all the bearings and everything would really help.
lwrider20 is offline
post #2 of (permalink) Old 08-09-2002, 04:53 AM
MrSurly's Avatar
Re: gear install
Do you have a copy of the FSM? That will help you more than anything. Did your R&P gears come with instructions? I'd like to know 'cause I'm regearing my diffs as well.
MrSurly is offline
post #3 of (permalink) Old 08-09-2002, 07:42 AM
Re: gear install
Randys ring &amp; pinion <a target="_blank" href=http://www.ringpinion.com>www.ringpinion.com</a> has lots of info about installing and what it takes. The FSM will give you the specifics such as torque settings. Definitely read the articles on ringpinion.com; it helped me a lot. As far as tools, you will need at least a dial indicator to set backlash. Plus torque wrench of course. Good luck! [img]images/icons/smile.gif[/img]
bansenshukai is offline
post #4 of (permalink) Old 08-09-2002, 10:33 AM
Re: gear install
What was said before about the FSM and the other R&amp;P site. Here's another from Izook:
http://izook.com/tech/diy/ringandpin...ndpinstall.htm
outlawmws is offline
post #5 of (permalink) Old 08-09-2002, 04:47 PM Thread Starter
Re: gear install
thnx for the help guys. surly my gears didnt come with instructions just some sheet that told me some better specs for backlash and thats about it.
post #6 of (permalink) Old 08-09-2002, 08:24 PM
Re: gear install
One tip that none of the instructions I've seen really stress: When your setting pinion bearing preload, make darn sure the bearings are well lubed. If you set the preload with the bearings dry, it will be way to low when they are lubed. Turning them dry can score the races also.
dschwab9 is offline
