Gti bottom end Q's - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-08-2002, 03:01 AM Thread Starter
Gti bottom end Q\'s
Where would be a good site to find info on swapping the Gti bottom end into my sammy? I still want to use the sumo II head and weber setup, so I need to research.
Doomhammer is offline
post #2 of (permalink) Old 08-08-2002, 04:45 AM
MrSurly's Avatar
Re: Gti bottom end Q\'s
Do a search on this board, or send a PM to Zukiman (Geoff Beasley). There are a lot of posts that deal with this swap. HTH
MrSurly is offline
post #3 of (permalink) Old 08-08-2002, 08:50 AM
Nowhere's Avatar
That is what I am doing. Parts are slowly comming in.
Nowhere is offline
post #4 of (permalink) Old 08-08-2002, 12:55 PM Thread Starter
Most of the post in the search are about transplanting the entire gti motor, I just want to use the short block and stick a sammy head on it. Will the short block bolt up to the sammy tranny or do I need an adapter?
post #5 of (permalink) Old 08-08-2002, 01:27 PM
I believe that is what Geoff B did.... so give him a holler....he is allways right there to help...
rich_d is offline
post #6 of (permalink) Old 08-08-2002, 01:34 PM
i think most people actually only use the short block of a GTI motor. They then use a sumoII head and usually a weber carb. It's supposed to be a high revving machine (8k or so redline).
hopefully this is what i will eventually do
TexasA&MOffRoad is offline
post #7 of (permalink) Old 08-08-2002, 01:56 PM
Nowhere's Avatar
I **think** the g13 series (k,b,a) of power blocks are exactly the same. No wait, there's that 138x cc motor and the 129x something motor.. Hmmm... I am under the impression that the blocks are a bolt up option.
Nowhere is offline
post #8 of (permalink) Old 08-08-2002, 02:14 PM
ronin
G13A and G13B blocks are the same, but the swift gti (G13B) uses stronger internal components to handle the higher rpms. The heads are the real major difference between the engines.
post #9 of (permalink) Old 08-08-2002, 02:23 PM
Nowhere's Avatar
The 13a is the 13xx cc engine?
the 13b is ther 129x cc engine?
Are the piston rings the same between all the 13xx and 12xx (13x series of blocks)?
Nowhere is offline
post #10 of (permalink) Old 08-08-2002, 02:27 PM
ronin
G13A (both 12xx and 13xx cc versions)is the SOHC engine in the Samurai, G13B is the DOHC in the swift GTi. Not sure about the piston rings question.
