couple of EFI questions......... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-02-2002, 10:30 AM
pugrocker
well.....I just changed over my 1.6L 8 valve to EFI and there are a couple of things I am pondering over:
1.) Sometimes the airfilter (box,hose,etc.) make a strange thumping noise as it is pulling in air (almost sounds like a tug boat) and it is really noticable when the headlights or heater is on????
2.) The idle at times is a little rougher than desired???? (I just changed spark plug wires, plugs (cap and rotor) all have less than 1000 miles on them and I cleaned out the EGR valve).......what else should I check???
3.) And sometimes (again, more than desired) when I push in the clutch the idle will drop really low (300-500 rpms) and then go up to normal idle speed????
....anyone with an EFI setup have any suggestions or tips for me - TIA
post #2 of (permalink) Old 08-02-2002, 12:10 PM
Re: couple of EFI questions.........
1. I dunno I run an open K&N element.
2. Also dunno, most of them seem to idle a bit rough, it's a 4 cylinder.
3. Mine idles around 500 all the time once it's warmed up.
Did you fix that EGR thingamabob?
Mini4x is offline
post #3 of (permalink) Old 08-02-2002, 12:58 PM
Nowhere's Avatar
HAHAAH, I am the master! [img]images/icons/laugh.gif[/img]
Ground wire please.
10 guage strap from the distrib to the firewall. Check/clean/replace the ground from the battery to the ENGINE/STARTER, and while you're there change/add a ground from the battery to the firewall. The clutch cable is acting as a ground. Carefull, you can nuke that thing if you don't check/replace/clean your cables..
Nowhere is offline
