Air/Fuel Meter - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-01-2002, 08:43 PM Thread Starter
Zukinator's Avatar
Air/Fuel Meter
Anyone have one of these? Any recommended brand names (affordable)?
Thanks.
Zukinator is offline
post #2 of (permalink) Old 08-01-2002, 08:53 PM
Re: Air/Fuel Meter
You can actually use a digital voltmeter hooked straight to the O2 sensor. Just hook it up and use it as a temp situation, but you must find out which voltages indicate lean, rich, etc. and there are places on the net for that. I have some of that info somewhere, I will look for it and let you know.
The gauges can be pricey for a poor person like me, but Summit has several. People have told me that it is better to avoid the LED gauges. I have no actual experience with the gauges.
Good luck and I will try to find the info for you,
Jim
JimC is offline
post #3 of (permalink) Old 08-02-2002, 03:08 PM
Re: Air/Fuel Meter
Some of the led gauges are good, yo just need to make sure it comes with its own converter(computer). These ones tend to run between 100 to 300 dollars but the are extremely accurate. If you have a weber I would save your money and buy a good one. I have used them one other vehicles to get them to pass emissions.( makes adjusting carbs really easy)
Doomhammer is offline
post #4 of (permalink) Old 08-02-2002, 03:15 PM
Re: Air/Fuel Meter
Doom, A digital VOM can be had for $20-$25. And it can be used on any vehicle you own. Good article on doing this, (just ignore the fact itsd about Holley's it still works the same.):
http://www.bob2000.com/carb.htm
outlawmws is offline
post #5 of (permalink) Old 08-13-2002, 06:10 AM
Re: Air/Fuel Meter
I finally found the link to help with air/fuel mixture monitoring.
http://www.dorianyeager.com/carb.html
It refers mostly to Q-Jets, but the same technology holds true for all carbs.
Jim
JimC is offline
post #6 of (permalink) Old 08-13-2002, 09:34 AM
Re: Air/Fuel Meter
Um, "I finally found the link "???
The content of that link was cut word for word from the link I put up. Looks like some one has been plagerizing?
post #7 of (permalink) Old 08-13-2002, 07:57 PM
Re: Air/Fuel Meter
Shows you that someone else knows a good thing too.
That looks like the way to really dial in a carb.
Jim
JimC is offline
post #8 of (permalink) Old 08-13-2002, 08:32 PM
Re: Air/Fuel Meter
Yep it works great.
post #9 of (permalink) Old 08-13-2002, 09:14 PM Thread Starter
Zukinator's Avatar
Re: Air/Fuel Meter
Thanks for the information - exactly what I was looking for. I won't need to buy anything, which is great.
post #10 of (permalink) Old 08-14-2002, 10:40 AM
Re: Air/Fuel Meter
it is saying that the oxygen sensor is producing a + voltage how is this? is it converting heat into energy it would seem as though it should be a ground i did hook up a tester to mine and it did show power (some how) but the readings make no sence maybe my o2 sensor is bad are you suposed to set it at an idle or at freeway rpm because mine varried it allways seemed about 900 at freeway speeds no matter where the air feul screw was set
szki272 is offline
