Both front shocks blown!!!!!!!!!!!!!!!!!!!!! *DELETED* - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-01-2002, 10:47 AM Thread Starter
Post deleted by Steveitalian
Steveitalian is offline
post #2 of (permalink) Old 08-01-2002, 11:04 AM
Re: Both front shocks blown!!!!!!!!!!!!!!!!!!!!!
Too funny. I did the same thing, but only bent them. I didn't do a good enough job making sure I had enough clearance there
CorvetteChris is offline
post #3 of (permalink) Old 08-01-2002, 11:07 AM Thread Starter
how did you solve the problem? should i go with a front top relocation kit?
post #4 of (permalink) Old 08-01-2002, 11:07 AM
I'm not quite sure if I understand you right, but did you extend your bump stops?
post #5 of (permalink) Old 08-01-2002, 11:08 AM Thread Starter
yes i got the spacers
post #6 of (permalink) Old 08-01-2002, 11:09 AM
I'll take a picture later. Basically, the instructions said to trim the spring plates. I used and angle grinder, but did not cut away enough. The inch or so that the axle will move during extreme flex, caused it to hit there. The axle moves forward a back a bit. It also hit on the bumpstop area.
Fyi.. bump stops would not affect movement in the front back direction.
post #7 of (permalink) Old 08-01-2002, 11:11 AM Thread Starter
If i drive up on something 6" tall with one front wheel my shock is a 1/4" away from that plate. This is the same for both sides.
post #8 of (permalink) Old 08-01-2002, 11:11 AM
I cut away a lot more of the areas in question. I think that will solve it (unless axle wrap is the problem)
post #9 of (permalink) Old 08-01-2002, 11:12 AM
just cut off the square end of the plate,...the edge... and that should fix the problem...
if I understand you correctly, your lower mount for the front shocks is below the u-bolt plate?
and that the u-bolt plate edge pierced your shocks blowing them out?
I figured that was going to happen to mine when i put them on so I took the dremel tool out and cut off the edge and rounded the courner off which gave me an extra .5 inch of clearance from my shocks...worked great and have yet to hit my shocks with it....
hope this helps..
rich_d is offline
post #10 of (permalink) Old 08-01-2002, 11:14 AM
Thanks for clearing it up. I read it a few times, maybe I didnt have enough coffee today.
