YJ spring conv. (Home made)? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-02-2002, 08:02 PM Thread Starter
"OK" here it is~ I have a set F&R of 2" lifted YJ springs that I'm itching to put on befor Zukiemelt!!! ~Problem~ no mulla to get the kits with!! SOOOOOO here is what I'm thinking of doing, I allready have 1" longer shackles on swing end of springs F&R. Hopfully the extra long shackle will swing back compensating for the extra length on that end. For the fixed end ~ I have some steel plates that were part of a genrick shackle lift kit. I put the spring in place and it lookes like they will bolt up with the plates bolted in where the stock spring is bolted in on the fixed end and then extend back just beyond the exhisting bracket giving me the extra length I need for the longer springs. (YJ springs would end up just behind the stock bracket that is allready welded in ~that is the stock one) In addition to bolting these plates in I could also weld them to the old brackets! (Plates are 1/8 " thick)
Question ~ how much longer , or more room do I need between the brackets for the YJ springs compared to the stock position?
What do yall think?? It looks like it might work! only thing I'm wondering about is side to side movement, not being shure if the extended brackets would hold UP . and if the extra long shackles are long enough.
I am also thinking of enlarging the holes on the bottom spring plates where the shocks and springs are bolted to the axel so the wider springs will fit!
OK ~ Let me have IT!!!!! Pros & Cons ~~~
OLDCODGER is offline
post #2 of (permalink) Old 07-02-2002, 08:49 PM
mikrosilakhan
Re: YJ spring conv. (Home made)?
I havent done my front yet but the rear was pretty easy. I made 1 inch longer shackels.I cant think of how to tellyou i moved the front mounts foward but it was easy.. Ill try and get a pic so you can compare it..
post #3 of (permalink) Old 07-02-2002, 08:51 PM Thread Starter
Will be looking for the pic, Thanks!!
post #4 of (permalink) Old 07-02-2002, 09:00 PM
Pooh-Bah
DougO's Avatar
I replied on Topica with a couple pic links for the rear, which I guess you could do for the front also, adjusting for the extra length needed though
DougO is offline
post #5 of (permalink) Old 07-02-2002, 09:18 PM Thread Starter
Thanks !! I went over and got them!!
post #6 of (permalink) Old 07-03-2002, 01:15 AM
dparker's Avatar
get a chance i have a few pics of my home made setup on my website
dparker is offline
post #7 of (permalink) Old 07-03-2002, 01:46 AM
hey parker on your website you have an adapter for a VW carb was that to run a weber or what??
studlybil03 is offline
post #8 of (permalink) Old 07-03-2002, 12:37 PM
sounds like you are planning on doing a shackle reversal one thing to remember is you will need a long travel front driveline if you do a shackel reversal if you do a non shackle reversal then you can use the stock front drive line
szki272 is offline
