Pumps & Pulleys ?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-25-2002, 02:54 PM Thread Starter
CrowHorse's Avatar
Pumps & Pulleys ??
I'm replacing my p/s pump and have discovered some differences in mine and the replacement. Mine is from a 91 Kick, and is all steel. The replacement is made by KYB and is all aluminum. I really don't care what it's made from, but here's my problem. The replacement has a bent pulley, so I thought I would swap pulleys. First off, I'm having a hell of a time getting the pulley off the KYB unit as there isn't a nut securing it. Secondly, the pump with the good pulley does have a nut and the pulley is somewhat different. Even if I do separate the pumps from the pulleys, I don't know for sure if they are interchangeable. Does anyone have any experience with this?
AAaaaaarrrrrrrrghhhhhh!!!!!!
That being said...thanks!
CrowHorse is offline
post #2 of (permalink) Old 06-25-2002, 03:02 PM
pugrocker
Re: Pumps & Pulleys ??
just out of curiosity - is the mounting different too? (in other words - does it mount like mine does or the same way as the previous model did?)
On another note - did you find out about the cross over steering swaps?
!~pUg~!
post #3 of (permalink) Old 06-25-2002, 03:14 PM
pugrocker
sorry to get off topic Crow - but I was wondering of the breeze x-over steering requires the stock steering stabilizer - didn't want to forget to ask you.......and I don't have one......
!~pUg~!
post #4 of (permalink) Old 06-25-2002, 03:47 PM Thread Starter
CrowHorse's Avatar
It appears the the mounting is the same between the two pumps. What I also discovered is that the feed line from the rez to the pump looks to be larger than the one I have. The high pressure hose (came with the pump) has different bends than mine and there is a metal tang on the hose fitting where it meets the steering box. Geez, I thought this would be a simple part replacement...I should know better by now.....
Not yet....but I'll call Tim shortly.....
post #5 of (permalink) Old 06-25-2002, 04:27 PM
why are you replacing pumps? and where did you get this new pump from?
TexasA&MOffRoad is offline
post #6 of (permalink) Old 06-25-2002, 04:38 PM Thread Starter
CrowHorse's Avatar
My pump has been making a squealing noise, not belt related. The replacement pump is used.....
post #7 of (permalink) Old 06-25-2002, 08:53 PM
Journeyman
Hi Crow -
The pulley is not designed to come off of the aluminum type pumps and the pulleys are not interchangeable. You should try to find a pre-'96 steel pump or a '96-up pump with hose. The high pressure hose is different. The mounting of the 2 pumps will be the same.
Bazuka is offline
post #8 of (permalink) Old 06-25-2002, 08:59 PM
Crow ,
If one pump doesn't have a retaining nut , and the other does, the two pulleys probably won't interchange. One is pressed on , the other isn't . I'd say get a different pump , just to avoid the headaches....
Sarge
Sarge is offline
post #9 of (permalink) Old 06-26-2002, 03:54 AM Thread Starter
CrowHorse's Avatar
Thanks guys....back to the drawing board..... \
Brent, do you have any pre 96 steel pumps in stock? I'll give you a call....
