axles...how do they come apart?...help me - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-08-2002, 01:43 PM Thread Starter
freebird01's Avatar
im tryin to get the rear haxle shafts out of a rear axle...how do these damn things come out? is like a ford 9" ? i got the back plates loose...now the axles will not come out...
any tricks tips or secrets??
freebird01 is offline
post #2 of (permalink) Old 06-08-2002, 01:49 PM
Re: axles...how do they come apart?...help me
Take the 4 bolts out of the center of the wheel hub. Put your tire back on and kick the tire from the underneath the car(provided you have the car on proper stands). You'll eventually get the axles to push out. It shouldn't take very much work to do this. If you are just taking the axles out to remove the third member then you don't need to take off the brake lines as you can push the axle out just far enough for the splined ends to back out of the third member.
I hope this helps.
Pauly
Capn_Crunch is offline
post #3 of (permalink) Old 06-08-2002, 03:19 PM
either that way or use a slide hammer.......... thats how i take mine off........ [img]images/icons/smile.gif[/img]
mudmagnet is offline
post #4 of (permalink) Old 06-08-2002, 03:25 PM
Hook up a chain to the four bolts and yank real hard a few times, or put the tire back on and hit real hard w/ a BFH. All of that is assuming you don't have a slide hammer.
Samurai202 is offline
post #5 of (permalink) Old 06-08-2002, 06:58 PM Thread Starter
freebird01's Avatar
well i got them out...thanks guys but none of those suggestions worked...these things were stubborn.....
picture it....2 chains, a large pickup, and a samurai
lets just say i got them out....muhahahahahahaha
post #6 of (permalink) Old 06-09-2002, 12:18 PM
Brown29's Avatar
A pickup truck??? I've never seen one that a size 9 1/2 Redwing with a 200 lb handle on it wouldn't remove. It must have been on there!
Brown29 is offline
post #7 of (permalink) Old 06-09-2002, 03:21 PM Thread Starter
freebird01's Avatar
well...my 9 1/2 wolverine steel tips didnt work...neither did yanking on the wheel...a good sized snap-on dead blow....or a pry bar....i dont own a slide hammer ....so i made a 2000lb slide hammer :-)
after beating on the axle for an hour and a half it kinda had me pissed off....even my ford 9" in the bronco never gave me this much trouble...used the samurai and it took me 5 minutes muhahahahahah!!! now my neighbor can say he lives nextdoor to a real redneck
*note* this was a spare axle...im using the housing to weld the spoa pads on...not the axle currently in my zuk...
post #8 of (permalink) Old 06-09-2002, 04:33 PM
1 question:
did you have the brakes locked while you were removing the axle? It sounds like that might have been the problem. I've pulled apart a few axles and NEVER had them give me that much trouble.
post #9 of (permalink) Old 06-09-2002, 04:41 PM Thread Starter
freebird01's Avatar
nope....all the brakes were free...in fact i completely removed all te brake hardware before i tried getting the axles out
post #10 of (permalink) Old 06-09-2002, 06:05 PM
mikrosilakhan
once you have them out they come out alot easier from now on.
