Hilarious post about tools. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-17-2002, 08:18 PM
mikrosilakhan
This has been graciously stolen from www.mudnuts.org . Its way to funny to pass up .
It's been a while since I've seen this posted anywhere so I figured I'd throw it up for sh!ts and giggles...
Subject: Only the mechanically inclined will understand
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate expensive parts not far from
the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on boxes containing leather goods.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in
their holes until you die of old age.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads and transfer intense welding
heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your garage on fire.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or 1/2
socket you've been searching for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that freshly
painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprint
whorls and hard-earned guitar callouses in about the time it takes you
to say, "Ouc...."
HYDRAULIC FLOOR JACK: Used for lowering a car to the ground after you
have installed your new front disk brake setup, trapping the jack handle
firmly under the fender.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a
hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor to see if he has another hydraulic
floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and
is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
strength of ground straps and brake lines you may have forgotten to
disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool
that inexplicably has an accurately machined screwdriver tip on the end
without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid
from a car battery to the inside of your toolbox after determining that
your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop
light, it is a good source of vitamin D, "the sunshine vitamin," which
is not otherwise found under motorcycles at night. Health benefits
aside, its main purpose is to consume 40-watt light bulbs at about the
same rate that 105-mm howitzer shells might be used during, say, the
first few hours of the Battle of the Bulge. More often dark than light,
its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used,
as the name implies, to round out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
bolts last tightened 60 years ago by someone in Springfield, and rounds
them off.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
post #2 of (permalink) Old 05-17-2002, 08:37 PM
Re: Hilarious post about tools.
LMFAO>>>>......
Sarge
Sarge is offline
post #3 of (permalink) Old 05-17-2002, 09:04 PM
haha! this'll be great for WORK PLACE! oh ya, i got a job at a hardware store! THX!
post #4 of (permalink) Old 05-17-2002, 10:07 PM
mikrosilakhan
I never do this but its worht placing back to top for sure [img]images/icons/smile.gif[/img]
post #5 of (permalink) Old 05-17-2002, 10:45 PM
....For cutting hoses 1/2 inch too short...That one had me rollin pretty good.
