MySU2 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-17-2002, 03:12 AM
Alfie
MySU2
Dang! i'lltry agin.
Not very good pic but next time i get the use of a digi i'll do better. It really is pretty, honest! I know y'all want to see it
Alfie.
post #2 of (permalink) Old 05-17-2002, 08:44 AM
Re: MySU2
All right! You ave my attention!
Details!
More more more
Ionsponge is offline
post #3 of (permalink) Old 05-17-2002, 04:56 PM
Alfie
Re: MySU2
OK it's a 1 & 3/4 inch SU (44mm)
It sits at an angle of 30 degrees.
I bought it from a vintage car specialist, rebuilt and to my specs.
He supplied an air filter adaptor which I used to make the cannister you see in the photo.
I opened up the intake to one big hole and used a stainless steel bend which I squashed at one end to match the intake hole.
A couple of plates cut to suit at each end and I had a manifold adaptor.
I relocated the airbox a few inches forward to allow the cannister to mate up.
Made a new throttle cable. Le Voila! A carb that allows great performance and NO flooding due to the float bowl being beside the main body of the carb.
With these carbs the main jet is matched to the carb, all you change is the needles. ( just like a motor cycle carb needle) These are available in a myriad of tapers and allow simple tuning.
Single throat means no balancing of duals.
And the choke is a main jet enrichening device which means no venturi obstruction with a choke butterfly.. When the main throttle is wide open it's almost a straight tube to the engine.
As I said, simple, efficient, and (almost) foolproof.
No vacuum hoses, switches, funny little doodads and tiny passages to get blocked etc.
Alfie.
post #4 of (permalink) Old 05-17-2002, 07:35 PM
Re: MySU2
Just be careful with that SU around heat , they can and sometimes do warp . Other than that, they are a great carb, I think there are aftermarket adapters to use the SU's with the Hitachi bolt pattern...
Sarge
Sarge is offline
