Front wheel bearings - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-16-2002, 09:41 PM Thread Starter
Im gona do the front wheel bearings this weekend and hints to make it go easyer?????...thanks fer the help
AZZZUKI is offline
post #2 of (permalink) Old 05-16-2002, 11:15 PM
Re: Front wheel bearings
The only problem I've ever had was when replaceing the clip on the end of the axel.The axel keeps slideing back in so I use one of the hub bolts screwed into the axel a few threads and then I can hold the axel out where I need it.
sky_hi_samurai is offline
post #3 of (permalink) Old 05-16-2002, 11:23 PM
Snap ring pliers for the clips,helps alot.
mudslide is offline
post #4 of (permalink) Old 05-16-2002, 11:35 PM
MrSurly's Avatar
When replacing the bearing races, you can use one of the old races as an installation tool to help you drive the new races into position. Also, don't forget to replace the inner grease seals while you're in there. HTH
MrSurly is offline
post #5 of (permalink) Old 05-17-2002, 12:05 AM Thread Starter
Kool , thanks fer the info....Rob
AZZZUKI is offline
post #6 of (permalink) Old 05-17-2002, 11:37 AM
Nowhere's Avatar
Check your king pin bearings also. You might want to rebuild the whole blasted thing! [img]images/icons/laugh.gif[/img]
Nowhere is offline
post #7 of (permalink) Old 05-17-2002, 03:10 PM
MrSurly's Avatar
Good advice. I put new wheel bearings, races, grease seals, rotors and pads on mine last July. Less than a year later, I found that my kingpin bearings were shot. Then I had to take everything back apart a second time. Live and learn!
MrSurly is offline
