Jay,
With all your pacific rim parts scrounging, can you find out about the hi-pinion diffs that MAY appear in post-95 SJ413's and Jimny's? In particular, is the carrier inside the same as a 2 or 4 pin carrier found in the Sammy (if yes, great) and it it will fit inside a Sammy axle housing (is yes, even greater)
If this is true, you may want to import these diff housings.
