a/c works to well ? 1989 GEO TRACKER - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-12-2002, 06:22 PM
I just got this tracker and the a/c will not turn off the switch on the dash is ok I checked it with a test light Looking in the Haynes repair manual wireing system it looks like it may be a bad a/c amplifier? Has anyone run in to this problem ? or anyone know where the a/c amplifier is mounted? Thanks Pete
post #2 of (permalink) Old 05-12-2002, 07:58 PM
ackerdackerly's Avatar
Re: a/c works to well ? 1989 GEO TRACKER
Wow! It's A/C Sunday here at Offroad.com!
Try this:
there is a wire that connects the magnnetic clutch on the front of your AC compressor unit mounted on the driver's side of the engine up front. (The magnetic clutch engages the compressor to the drive pulley when you turn on the A/C) It may be black and has a snap connector somewhere on it. Disconnect this wire and then start your engine.
If you STILL get frosty-cold air with the air conditioner turned off, then you have a locked-up Compressor clutch!
Time to replace the compressor (unless anyone else out there has a way to fix a frozen clutch...)
ackerdackerly is offline
post #3 of (permalink) Old 05-12-2002, 08:10 PM
Thanks for the reply, When I pull the dual pressure switch at the dryer the clutch will cut off. The compressor runs all the time when pluged back, It will not even cycle just runs and runs and runs. Pete
post #4 of (permalink) Old 05-12-2002, 08:13 PM
Oops!
That's as far as my pea-brain can help... sounds like a sensor or something... good luck -- and back to the top of the post list!
post #5 of (permalink) Old 05-12-2002, 10:33 PM
There is probably a thermostat on the evaporator, either stuck into the core, or in the airstream on the outlet side of the evaporator. Chances are it's stuck closed. This is probably the part you're looking at on the schematic. It's a PITA to get to.
The switch on the dryer is just a safety, it opens if the liquid line pressure goes too high, or if the charge is lost.
The thermostatic switch on the evaporator is what actually cycles the compressor.
dschwab9 is offline
post #6 of (permalink) Old 05-13-2002, 06:23 AM
Thanks Derek Thats the the path I staterd down But it looks like somewere there is a rely or what the Haynes manual calls an A/C Amplifier on the schematic where all the sensors and relays connect! And they hid it well. It may be up under the dash someplace. But there is a nest of relys back by the left tail lamp I found yesterday and I don't have a clue yet as to what there for. Thanks much Pete
