front and rear chunk the same? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-05-2002, 08:05 PM
mikrosilakhan
Are the front and rear chunks the same? the search buttons 24 hour vacation is goin on about its second week. I only ask becuase i amlocked in the back and open in the front. seems the a welded rear looks way more controlable so i was gonna pull the chunks and swap them. I could swap the locker over but it would be sensless if there the same. thanks in advance
post #2 of (permalink) Old 04-05-2002, 08:12 PM
Re: front and rear chunk the same?
I think the splines on hte axles are diferent!
OLDCODGER is offline
post #3 of (permalink) Old 04-05-2002, 09:39 PM
Yes they are the same but you have to swap side gears the rear is a 26 spline and the front is 22. if you welded the rear you might not be able to swap.
Bill4rest is offline
post #4 of (permalink) Old 04-05-2002, 11:20 PM
could i then use the axles from the rear...wouldnt this make the axles Stronger???
post #5 of (permalink) Old 04-05-2002, 11:26 PM
mikrosilakhan
then ya coouldnt steer [img]images/icons/smile.gif[/img] i have about 15 different axles/chucks laying around so a complete swap would be way easier.... thanks guys..
post #6 of (permalink) Old 04-05-2002, 11:28 PM
i meant the inards.....
post #7 of (permalink) Old 04-05-2002, 11:29 PM
oh no, you would need to turn right? rear axles don't have a joint on them (ie birffield or U-joint)
And expensive way to do something is to take both rear axles cut and shave/spline them down th execpt the front birfield joint then slap some Birfield Rings on
post #8 of (permalink) Old 04-05-2002, 11:44 PM
no if you want those you can get some from calmini for about 300 total for both sides
post #9 of (permalink) Old 04-05-2002, 11:47 PM
I would want what?
post #10 of (permalink) Old 04-06-2002, 02:21 AM
daa were di they go george were did they go
I am having some trouble with new sammy/ the rear third member main bearing is bad the one that the drive shaft bolts up to/ has anyone changed one
I like some info
If i have to remove the axles and the third member i will wait and get me some lockers then replace the bearing/
